Beam Design - Roof Beam Sizing
Grade: 24F-V8 1.8E SP/SP
Size: 5.5 x 22
Design Span (L): 19.29 ft.
Clear Span: 18.83 ft.
Total Span: 19.75 ft.
Bearing (lb): 5.5 in.
Live Load: 712 plf
Dead Load: 503 plf
Selfweight: 598.0 lbs
Dist. Selfweight: 31.00 plf
Total Weight: 612.2 lbs
Notes: Sizing for the main roof beam, which bears the dead and live loads from both the south and north roofs, including solar PV and extensive green roof installations.
CV Volume Factor 0.971b - - - - -
Beam Design Steven Rhodes 1302 Tarragon Drive, Marysville OH 43040 CPH1
5/29/2021 1
d = 22.000 in.
A = 5.500 x 22.000 = 121.00 in.2
Sx = (5.500)(22.000)2/6 = 443.67 in.3
Sy = (5.500)2(22.000)/6 = 110.92 in.3
Ix = (5.500)(22.000)3/12 = 4880.33 in.4
Iy = (5.500)3(22.000)/12 = 305.02 in.4
5/29/2021 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [121.00 x (231.50 + 5.5)] x (12 in./ft.)3 = 16.60 ft3
Volumespan = N[A x L] = 1 x [121.00 x 231.50] x (12 in./ft.)3 = 16.21 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 16.60 = 612.2 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 16.21 = 598.0 lbs
Distributed Self Weight (ws) = = 31.00 plf
712 plf
503 plf
  ws = 31.00 plf
19.29 ft.
18.83 ft.
19.75 ft.
12304.43 lbs
12304.43 lbs
5/29/2021 3
CV = = 0.971
CV = 0.971 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.971) = 2679.5 psi
fb = = 1567.9 psi
 fb = 1567.9 psi < Fbx' = 2679.5 psi  (CSI = 0.59)   ➜  OK
5/29/2021 4
fv* = = 120.68 psi
 fv* = 120.68 psi < Fvx' = 345.00 psi  (CSI = 0.35)   ➜  OK
fv = = 148.99 psi
 fv = 148.99 psi < Fvx' = 345.00 psi  (CSI = 0.43)   ➜  OK
5/29/2021 5
ΔLL = = 0.25 in.
(L/d)LL = 231.50 / 0.25 = 916
 ΔLL = 0.25 in = L/916 < L/180   ➜  OK
ΔTL = = 0.44 in.
(L/d)TL = 231.50 / 0.44 = 524
 ΔTL = 0.44 in = L/524 < L/120   ➜  OK
fc⊥ = = 406.8 psi
 fc⊥ = 406.8 psi < Fc⊥x' = 740.00 psi  (CSI = 0.55)   ➜  OK
5/29/2021 6
