Size: 4 x 4
Design Span (L): 3.25 ft.
Clear Span: 3.00 ft.
Total Span: 3.50 ft.
Live Load: 460 plf
Dead Load: 0 plf
Selfweight: 9.5 lbs
Dist. Selfweight: 2.91 plf
Total Weight: 10.2 lbs
Orientation: Horizontal
Beam Design 2021A342
5/28/2021 1
d = 3.500 in.
5/28/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [12.25 x (39.00 + 3)] x (12 in./ft.)3 = 0.30 ft3
Volumespan = N[A x L] = 1 x [12.25 x 39.00] x (12 in./ft.)3 = 0.28 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.30 = 10.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.28 = 9.5 lbs
460 plf
0 plf
ws = 2.91 plf
3.25 ft.
3.00 ft.
3.50 ft.
810.09 lbs
810.09 lbs
5/28/2021 3
Fby' = (900)(1.00)(1)(1)(1)(1.5)(1)(1)(1) = 1350.0 psi
fb = = 1026.4 psi
 fb = 1026.4 psi < Fby' = 1350.0 psi  (CSI = 0.76)   ➜  OK
5/28/2021 4
Fvy' = (180)(1.00)(1)(1)(1) = 180.00 psi
fv* = = 75.58 psi
 fv* = 75.58 psi < Fvy' = 180.00 psi  (CSI = 0.42)   ➜  OK
fv = = 92.11 psi
 fv = 92.11 psi < Fvy' = 180.00 psi  (CSI = 0.51)   ➜  OK
5/28/2021 5
ΔLL = = 0.06 in.
(L/d)LL = 39.00 / 0.06 = 676
 ΔLL = 0.06 in = L/676 < L/360   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 39.00 / 0.06 = 672
 ΔTL = 0.06 in = L/672 < L/240   ➜  OK
Ab = d x lb = 3.5 x 3 = 10.50 in2
fc⊥ = = 77.2 psi
 fc⊥ = 77.2 psi < Fc⊥y' = 625.00 psi  (CSI = 0.12)   ➜  OK
5/28/2021 6
