Grade: SP SS
Design Span (L): 8.25 ft.
Clear Span: 8.00 ft.
Total Span: 8.50 ft.
Live Load: 720 plf
Dead Load: 200 plf
Selfweight: 72.2 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 74.4 lbs
Load Duration: 1.60
Beam Design 2021A341
5/28/2021 1
SP SS 1600 1100 175 565 1650 1800000 660000 0.55
5/28/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (99.00 + 3)] x (12 in./ft.)3 = 1.99 ft3
Volumespan = N[A x L] = 2 x [16.88 x 99.00] x (12 in./ft.)3 = 1.93 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.99 = 74.4 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.93 = 72.2 lbs
720 plf
200 plf
ws = 8.75 plf
8.25 ft.
8.50 ft.
3947.18 lbs
3947.18 lbs
5/28/2021 3
Fbx' = (1600)(1.60)(1)(1)(1)(1)(1)(1) = 2560.0 psi
fb = = 1498.4 psi
 fb = 1498.4 psi < Fbx' = 2560.0 psi  (CSI = 0.59)   ➜  OK
5/28/2021 4
Fvx' = (175)(1.60)(1)(1)(1) = 280.00 psi
fv* = = 131.57 psi
 fv* = 131.57 psi < Fvx' = 280.00 psi  (CSI = 0.47)   ➜  OK
fv = = 170.27 psi
 fv = 170.27 psi < Fvx' = 280.00 psi  (CSI = 0.61)   ➜  OK
5/28/2021 5
ΔLL = = 0.12 in.
(L/d)LL = 99.00 / 0.12 = 845
 ΔLL = 0.12 in = L/845 < L/240   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 99.00 / 0.15 = 655
 ΔTL = 0.15 in = L/655 < L/180   ➜  OK
fc⊥ = = 438.6 psi
 fc⊥ = 438.6 psi < Fc⊥x' = 565.00 psi  (CSI = 0.78)   ➜  OK
5/28/2021 6
