Grade: SP No.1
Design Span (L): 7.76 ft.
Clear Span: 7.30 ft.
Total Span: 8.22 ft.
Bearing (lb): 5.5 in.
Live Load: 375 plf
Dead Load: 95 plf
Selfweight: 57.7 lbs
Dist. Selfweight: 7.44 plf
Total Weight: 61.1 lbs
Beam Design 2021A340
5/28/2021 1
5/28/2021 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (93.10 + 5.5)] x (12 in./ft.)3 = 1.58 ft3
Volumespan = N[A x L] = 2 x [13.88 x 93.10] x (12 in./ft.)3 = 1.50 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 1.58 = 61.1 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 1.50 = 57.7 lbs
Distributed Self Weight (ws) = = 7.44 plf
375 plf
95 plf
ws = 7.44 plf
7.76 ft.
7.30 ft.
8.22 ft.
1961.38 lbs
1961.38 lbs
5/28/2021 3
Fbx' = (1050)(1.15)(1)(1)(1)(1)(1)(1) = 1207.5 psi
fb = = 1007.5 psi
 fb = 1007.5 psi < Fbx' = 1207.5 psi  (CSI = 0.83)   ➜  OK
5/28/2021 4
fv* = = 80.21 psi
 fv* = 80.21 psi < Fvx' = 195.21 psi  (CSI = 0.41)   ➜  OK
fv = = 100.11 psi
 fv = 100.11 psi < Fvx' = 195.21 psi  (CSI = 0.51)   ➜  OK
5/28/2021 5
ΔLL = = 0.11 in.
(L/d)LL = 93.10 / 0.11 = 868
 ΔLL = 0.11 in = L/868 < L/360   ➜  OK
ΔTL = = 0.14 in.
(L/d)TL = 93.10 / 0.14 = 682
 ΔTL = 0.14 in = L/682 < L/240   ➜  OK
fc⊥ = = 118.9 psi
 fc⊥ = 118.9 psi < Fc⊥x' = 378.55 psi  (CSI = 0.31)   ➜  OK
5/28/2021 6
