Beam Design - 6 3/4 x 21 GL
Size: 6.75 x 22.5
Design Span (L): 17.17 ft.
Clear Span: 16.83 ft.
Total Span: 17.50 ft.
Bearing (lb): 4 in.
Live Load: 1500 plf
Selfweight: 611.3 lbs
Dist. Selfweight: 35.61 plf
Total Weight: 623.1 lbs
CV Volume Factor 0.932b - - - - -
Beam Design B Holmes GWE L9
1/14/2021 1
b = 6.750 in.
d = 22.500 in.
A = 6.750 x 22.500 = 151.88 in.2
Sx = (6.750)(22.500)2/6 = 569.53 in.3
Sy = (6.750)2(22.500)/6 = 170.86 in.3
Ix = (6.750)(22.500)3/12 = 6407.23 in.4
Iy = (6.750)3(22.500)/12 = 576.65 in.4
1/14/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [151.88 x (206.00 + 4)] x (12 in./ft.)3 = 18.46 ft3
Volumespan = N[A x L] = 1 x [151.88 x 206.00] x (12 in./ft.)3 = 18.11 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 18.46 = 623.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 18.11 = 611.3 lbs
Distributed Self Weight (ws) = = 35.61 plf
1500 plf
  ws = 35.61 plf
17.17 ft.
16.83 ft.
17.50 ft.
14093.08 lbs
14093.08 lbs
1/14/2021 3
CV = = 0.932
CV = 0.932 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.932) = 2572.8 psi
fb = = 1250.1 psi
 fb = 1250.1 psi < Fbx' = 2572.8 psi  (CSI = 0.49)   ➜  OK
1/14/2021 4
fv* = = 106.71 psi
 fv* = 106.71 psi < Fvx' = 304.75 psi  (CSI = 0.35)   ➜  OK
fv = = 136.54 psi
 fv = 136.54 psi < Fvx' = 304.75 psi  (CSI = 0.45)   ➜  OK
1/14/2021 5
ΔLL = = 0.25 in.
(L/d)LL = 206.00 / 0.25 = 811
 ΔLL = 0.25 in = L/811 < L/360   ➜  OK
ΔTL = = 0.27 in.
(L/d)TL = 206.00 / 0.27 = 755
 ΔTL = 0.27 in = L/755 < L/240   ➜  OK
Ab = b x lb = 6.75 x 4 = 27.00 in2
fc⊥ = = 522.0 psi
 fc⊥ = 522.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.80)   ➜  OK
1/14/2021 6
