Grade: 24F-V3 1.8E SP/SP
Size: 5.5 x 12.375
Design Span (L): 15.21 ft.
Clear Span: 14.75 ft.
Total Span: 15.67 ft.
Bearing (lb): 5.5 in.
Live Load: 282.9 plf
Dead Load: 424.3 plf
Selfweight: 265.2 lbs
Dist. Selfweight: 17.44 plf
Total Weight: 273.2 lbs
Beam Design 2021A338
5/27/2021 1
d = 12.375 in.
A = 5.500 x 12.375 = 68.06 in.2
Sx = (5.500)(12.375)2/6 = 140.38 in.3
Sy = (5.500)2(12.375)/6 = 62.39 in.3
Ix = (5.500)(12.375)3/12 = 868.59 in.4
Iy = (5.500)3(12.375)/12 = 171.57 in.4
5/27/2021 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [68.06 x (182.51 + 5.5)] x (12 in./ft.)3 = 7.41 ft3
Volumespan = N[A x L] = 1 x [68.06 x 182.51] x (12 in./ft.)3 = 7.19 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 7.41 = 273.2 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 7.19 = 265.2 lbs
Distributed Self Weight (ws) = = 17.44 plf
282.9 plf
424.3 plf
  ws = 17.44 plf
15.21 ft.
14.75 ft.
15.67 ft.
5676.56 lbs
5676.56 lbs
5/27/2021 3
fb = = 1791.1 psi
 fb = 1791.1 psi < Fbx' = 2760.0 psi  (CSI = 0.65)   ➜  OK
5/27/2021 4
fv* = = 104.97 psi
 fv* = 104.97 psi < Fvx' = 345.00 psi  (CSI = 0.30)   ➜  OK
fv = = 121.44 psi
 fv = 121.44 psi < Fvx' = 345.00 psi  (CSI = 0.35)   ➜  OK
5/27/2021 5
ΔLL = = 0.22 in.
(L/d)LL = 182.51 / 0.22 = 838
 ΔLL = 0.22 in = L/838 < L/360   ➜  OK
ΔTL = = 0.56 in.
(L/d)TL = 182.51 / 0.56 = 327
 ΔTL = 0.56 in = L/327 < L/240   ➜  OK
fc⊥ = = 187.7 psi
 fc⊥ = 187.7 psi < Fc⊥x' = 740.00 psi  (CSI = 0.25)   ➜  OK
5/27/2021 6
