Grade: SPF No.2
Size: 4 x 4
Design Span (L): 2.00 ft.
Clear Span: 1.88 ft.
Total Span: 2.13 ft.
Bearing (lb): 1.5 in.
Live Load: 600 lbs
Dead Load: 0 lbs
Selfweight: 5.0 lbs
Dist. Selfweight: 2.48 plf
Total Weight: 5.3 lbs
Beam Design 2021A337
5/24/2021 1
d = 3.500 in.
5/24/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [12.25 x (24.00 + 1.5)] x (12 in./ft.)3 = 0.18 ft3
Volumespan = N[A x L] = 1 x [12.25 x 24.00] x (12 in./ft.)3 = 0.17 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.18 = 5.3 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.17 = 5.0 lbs
Distributed Self Weight (ws) = = 2.48 plf
600 lbs
0 lbs
ws = 2.48 plf
2.00 ft.
1.88 ft.
2.13 ft.
302.63 lbs
302.63 lbs
5/24/2021 3
Fbx' = (875)(1.00)(1)(1)(1)(1.5)(1)(1) = 1312.5 psi
fb = = 505.9 psi
 fb = 505.9 psi < Fbx' = 1312.5 psi  (CSI = 0.39)   ➜  OK
5/24/2021 4
fv* = = 36.95 psi
 fv* = 36.95 psi < Fvx' = 135.00 psi  (CSI = 0.27)   ➜  OK
fv = = 37.04 psi
 fv = 37.04 psi < Fvx' = 135.00 psi  (CSI = 0.27)   ➜  OK
5/24/2021 5
ΔLL =   =   = 0.01 in.
(L/d)LL = 24.00 / 0.01 = 2432
 ΔLL = 0.01 in = L/2432 < L/360   ➜  OK
ΔTL =   =   = 0.01 in.
(L/d)TL = 24.00 / 0.01 = 2419
 ΔTL = 0.01 in = L/2419 < L/240   ➜  OK
Ab = b x lb = 3.5 x 1.5 = 5.25 in2
fc⊥ = = 57.6 psi
 fc⊥ = 57.6 psi < Fc⊥x' = 425.00 psi  (CSI = 0.14)   ➜  OK
5/24/2021 6
