Beam Design - Deck Beam
Size: 2 x 4
Design Span (L): 5.23 ft.
Clear Span: 4.94 ft.
Total Span: 5.52 ft.
Bearing (lb): 3.5 in.
Live Load: 97 plf
Dead Load: 25 plf
Selfweight: 14.7 lbs
Dist. Selfweight: 2.81 plf
Total Weight: 15.5 lbs
Defl. Limits: 480|360
Beam Design Shaun Merrill 5881 Nile Dr SW 20210519
5/19/2021 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
SP No.2 1100 675 175 565 1450 1400000 510000 0.55
5/19/2021 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [5.25 x (62.75 + 3.5)] x (12 in./ft.)3 = 0.40 ft3
Volumespan = N[A x L] = 2 x [5.25 x 62.75] x (12 in./ft.)3 = 0.38 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 0.40 = 15.5 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 0.38 = 14.7 lbs
Distributed Self Weight (ws) = = 2.81 plf
97 plf
25 plf
ws = 2.81 plf
5.23 ft.
4.94 ft.
5.52 ft.
344.53 lbs
344.53 lbs
5/19/2021 3
Fbx' = (1100)(1.15)(1)(1)(1)(1)(1)(1) = 1265.0 psi
fb = = 835.8 psi
 fb = 835.8 psi < Fbx' = 1265.0 psi  (CSI = 0.66)   ➜  OK
5/19/2021 4
fv* = = 41.42 psi
 fv* = 41.42 psi < Fvx' = 195.21 psi  (CSI = 0.21)   ➜  OK
fv = = 46.62 psi
 fv = 46.62 psi < Fvx' = 195.21 psi  (CSI = 0.24)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
5/19/2021 5
ΔLL = = 0.12 in.
(L/d)LL = 62.75 / 0.12 = 519
 ΔLL = 0.12 in = L/519 < L/480   ➜  OK
ΔTL = = 0.16 in.
(L/d)TL = 62.75 / 0.16 = 404
 ΔTL = 0.16 in = L/404 < L/360   ➜  OK
fc⊥ = = 32.8 psi
 fc⊥ = 32.8 psi < Fc⊥x' = 378.55 psi  (CSI = 0.09)   ➜  OK
5/19/2021 6
