Beam Design - Deck Joist
Size: 2 x 4
Design Span (L): 2.60 ft.
Clear Span: 2.48 ft.
Total Span: 2.73 ft.
Bearing (lb): 1.5 in.
Live Load: 80 plf
Dead Load: 20 plf
Selfweight: 3.7 lbs
Dist. Selfweight: 1.41 plf
Total Weight: 3.8 lbs
Defl. Limits: 480|360
Beam Design Shaun Merrill 5881 Nile Dr SW 20210515
5/19/2021 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
SP No.2 1100 675 175 565 1450 1400000 510000 0.55
5/19/2021 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [5.25 x (31.25 + 1.5)] x (12 in./ft.)3 = 0.10 ft3
Volumespan = N[A x L] = 1 x [5.25 x 31.25] x (12 in./ft.)3 = 0.09 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 0.10 = 3.8 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 0.09 = 3.7 lbs
Distributed Self Weight (ws) = = 1.41 plf
80 plf
20 plf
ws = 1.41 plf
2.60 ft.
2.48 ft.
2.73 ft.
138.37 lbs
138.37 lbs
5/19/2021 3
Fbx' = (1100)(1.15)(1)(1)(1)(1)(1)(1.15) = 1454.8 psi
fb = = 336.8 psi
 fb = 336.8 psi < Fbx' = 1454.8 psi  (CSI = 0.23)   ➜  OK
5/19/2021 4
fv* = = 29.27 psi
 fv* = 29.27 psi < Fvx' = 195.21 psi  (CSI = 0.15)   ➜  OK
fv = = 37.72 psi
 fv = 37.72 psi < Fvx' = 195.21 psi  (CSI = 0.19)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
5/19/2021 5
ΔLL = = 0.01 in.
(L/d)LL = 31.25 / 0.01 = 2550
 ΔLL = 0.01 in = L/2550 < L/480   ➜  OK
ΔTL = = 0.02 in.
(L/d)TL = 31.25 / 0.02 = 2011
 ΔTL = 0.02 in = L/2011 < L/360   ➜  OK
fc⊥ = = 61.5 psi
 fc⊥ = 61.5 psi < Fc⊥x' = 378.55 psi  (CSI = 0.16)   ➜  OK
5/19/2021 6
