Beam Design - q
Design Span (L): 17.25 ft.
Clear Span: 17.00 ft.
Total Span: 17.50 ft.
Live Load: 100 lbs
Dead Load: 10 lbs
Selfweight: 44.6 lbs
Dist. Selfweight: 2.58 plf
Total Weight: 45.2 lbs
CL Beam Stability Factor 0.608 - - - - -
Beam Design j smith 1
5/17/2021 1
5/17/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (207.00 + 3)] x (12 in./ft.)3 = 1.32 ft3
Volumespan = N[A x L] = 1 x [10.88 x 207.00] x (12 in./ft.)3 = 1.30 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.32 = 45.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.30 = 44.6 lbs
100 lbs
10 lbs
ws = 2.58 plf
17.25 ft.
17.00 ft.
17.50 ft.
77.60 lbs
77.60 lbs
5/17/2021 3
lu = Unbraced Length = 17.250 ft.
lu/d = = 28.55
le = 1.37lu + 3d = 1.37(207.0) + 3(7.25) = 305.34 in. = 25.45 ft.  (NDS Table 3.3.3)
Rb = = 31.37
 Rb = 31.37 < 50   ➜  OK
5/17/2021 4
FbE = = 707.41 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.00)(1)(1)(1.2)(1)(1) = 1080.00 psi
CL =   = 0.608
Fbx' = (900)(1.00)(1)(1)(0.608)(1.2)(1)(1) = 656.5 psi
fb = = 520.9 psi
 fb = 520.9 psi < Fbx' = 656.5 psi  (CSI = 0.79)   ➜  OK
fv* = = 10.44 psi
 fv* = 10.44 psi < Fvx' = 180.00 psi  (CSI = 0.06)   ➜  OK
fv = = 10.66 psi
 fv = 10.66 psi < Fvx' = 180.00 psi  (CSI = 0.06)   ➜  OK
5/17/2021 5
ΔLL =   =   = 0.24 in.
(L/d)LL = 207.00 / 0.24 = 854
 ΔLL = 0.24 in = L/854 < L/360   ➜  OK
ΔTL =   =   = 0.33 in.
(L/d)TL = 207.00 / 0.33 = 619
 ΔTL = 0.33 in = L/619 < L/240   ➜  OK
fc⊥ = = 17.2 psi
 fc⊥ = 17.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.03)   ➜  OK
5/17/2021 6
