Size: 6.75 x 12
Design Span (L): 32.83 ft.
Clear Span: 32.17 ft.
Total Span: 33.50 ft.
Bearing (lb): 8 in.
Selfweight: 623.5 lbs
Dist. Selfweight: 18.99 plf
Total Weight: 636.2 lbs
Load Duration: 1.33
CL Beam Stability Factor 0.957 - - - - -
CV Volume Factor 0.930b - - - - -
Beam Design Brad gregory
5/14/2021 1
b = 6.750 in.
A = 6.750 x 12.000 = 81.00 in.2
Sx = (6.750)(12.000)2/6 = 162.00 in.3
Sy = (6.750)2(12.000)/6 = 91.13 in.3
Ix = (6.750)(12.000)3/12 = 972.00 in.4
Iy = (6.750)3(12.000)/12 = 307.55 in.4
5/14/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [81.00 x (394.00 + 8)] x (12 in./ft.)3 = 18.84 ft3
Volumespan = N[A x L] = 1 x [81.00 x 394.00] x (12 in./ft.)3 = 18.47 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 18.84 = 636.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 18.47 = 623.5 lbs
Distributed Self Weight (ws) = = 18.99 plf
  ws = 18.99 plf
32.83 ft.
32.17 ft.
33.50 ft.
3249.31 lbs
3249.31 lbs
5/14/2021 3
lu = Unbraced Length = 32.833 ft.
lu/d = = 32.83
le = 1.63lu + 3d = 1.63(394.0) + 3(12) = 678.21 in. = 56.52 ft.  (NDS Table 3.3.3)
Rb = = 13.37
 Rb = 13.37 < 50   ➜  OK
5/14/2021 4
Eminy' = Eminy(CM)(Ct) = 850000(1)(0.9) = 765000 psi
FbE = = 5139.28 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(1.33)(1)(0.8) = 2553.60 psi
CL =   = 0.957
CV = = 0.930
CV = 0.930 < CL = 0.957
Fbx' = (2400)(1.33)(1)(0.8)(0.930) = 2375.7 psi
fb = = 1936.3 psi
 fb = 1936.3 psi < Fbx' = 2375.7 psi  (CSI = 0.82)   ➜  OK
Fvx' = (265)(1.33)(1)(0.8) = 281.96 psi
fv* = = 55.38 psi
5/14/2021 5
 fv* = 55.38 psi < Fvx' = 281.96 psi  (CSI = 0.20)   ➜  OK
fv = = 58.97 psi
 fv = 58.97 psi < Fvx' = 281.96 psi  (CSI = 0.21)   ➜  OK
ΔLL = = 1.66 in.
(L/d)LL = 394.00 / 1.66 = 237
 ΔLL = 1.66 in = L/237 > L/360   ➜  NG
ΔTL = = 3.22 in.
(L/d)TL = 394.00 / 3.22 = 122
 ΔTL = 3.22 in = L/122 > L/240   ➜  NG
5/14/2021 6
Ab = b x lb = 6.75 x 8 = 54.00 in2
fc⊥ = = 60.2 psi
 fc⊥ = 60.2 psi < Fc⊥x' = 520.00 psi  (CSI = 0.12)   ➜  OK
5/14/2021 7
