Beam Design - Beam Calc
Size: 6.75 x 16.5
Design Span (L): 17.25 ft.
Clear Span: 17.00 ft.
Total Span: 17.50 ft.
Live Load: 1500 plf
Dead Load: 100 plf
Selfweight: 450.4 lbs
Dist. Selfweight: 26.11 plf
Total Weight: 457.0 lbs
CV Volume Factor 0.961b - - - - -
Beam Design B Holmes GWE L9 GWE L9
1/14/2021 1
b = 6.750 in.
d = 16.500 in.
A = 6.750 x 16.500 = 111.38 in.2
Sx = (6.750)(16.500)2/6 = 306.28 in.3
Sy = (6.750)2(16.500)/6 = 125.30 in.3
Ix = (6.750)(16.500)3/12 = 2526.82 in.4
Iy = (6.750)3(16.500)/12 = 422.88 in.4
1/14/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [111.38 x (207.00 + 3)] x (12 in./ft.)3 = 13.54 ft3
Volumespan = N[A x L] = 1 x [111.38 x 207.00] x (12 in./ft.)3 = 13.34 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 13.54 = 457.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 13.34 = 450.4 lbs
Distributed Self Weight (ws) = = 26.11 plf
1500 plf
  ws = 26.11 plf
17.25 ft.
17.00 ft.
17.50 ft.
14228.48 lbs
14228.48 lbs
1/14/2021 3
CV = = 0.961
CV = 0.961 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.961) = 2652.5 psi
fb = = 2369.7 psi
 fb = 2369.7 psi < Fbx' = 2652.5 psi  (CSI = 0.89)   ➜  OK
1/14/2021 4
fv* = = 158.78 psi
 fv* = 158.78 psi < Fvx' = 304.75 psi  (CSI = 0.52)   ➜  OK
fv = = 188.89 psi
 fv = 188.89 psi < Fvx' = 304.75 psi  (CSI = 0.62)   ➜  OK
1/14/2021 5
ΔLL = = 0.66 in.
(L/d)LL = 207.00 / 0.66 = 315
 ΔLL = 0.66 in = L/315 > L/360   ➜  NG
ΔTL = = 0.71 in.
(L/d)TL = 207.00 / 0.71 = 291
 ΔTL = 0.71 in = L/291 < L/240   ➜  OK
fc⊥ = = 702.6 psi
 fc⊥ = 702.6 psi > Fc⊥x' = 650.00 psi  (CSI = 1.08)   ➜  NG
1/14/2021 6
