Beam Design - Trinity Heights Header
Design Span (L): 6.30 ft.
Clear Span: 6.05 ft.
Total Span: 6.55 ft.
Live Load: 50 plf
Dead Load: 20 plf
Selfweight: 41.5 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 43.2 lbs
Beam Design Keith McClanahan 3600 N 4th St. BP-21-00984
5/10/2021 1
5/10/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (75.60 + 3)] x (12 in./ft.)3 = 1.26 ft3
Volumespan = N[A x L] = 2 x [13.88 x 75.60] x (12 in./ft.)3 = 1.21 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.26 = 43.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.21 = 41.5 lbs
50 plf
20 plf
ws = 6.59 plf
6.30 ft.
6.05 ft.
6.55 ft.
250.84 lbs
250.84 lbs
5/10/2021 3
fb = = 106.6 psi
 fb = 106.6 psi < Fbx' = 1138.5 psi  (CSI = 0.09)   ➜  OK
5/10/2021 4
fv* = = 9.85 psi
 fv* = 9.85 psi < Fvx' = 207.00 psi  (CSI = 0.05)   ➜  OK
fv = = 13.04 psi
 fv = 13.04 psi < Fvx' = 207.00 psi  (CSI = 0.06)   ➜  OK
5/10/2021 5
ΔLL = = 0.01 in.
(L/d)LL = 75.60 / 0.01 = 13505
 ΔLL = 0.01 in = L/13505 < L/180   ➜  OK
ΔTL = = 0.01 in.
(L/d)TL = 75.60 / 0.01 = 8816
 ΔTL = 0.01 in = L/8816 < L/120   ➜  OK
fc⊥ = = 27.9 psi
 fc⊥ = 27.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.04)   ➜  OK
5/10/2021 6
