Species: Hem-Fir
Grade: HF No.2
Design Span (L): 8.25 ft.
Clear Span: 8.00 ft.
Total Span: 8.50 ft.
Live Load: 450 plf
Dead Load: 60 plf
Selfweight: 59.9 lbs
Dist. Selfweight: 7.26 plf
Total Weight: 61.7 lbs
Beam Design 2021A32
1/14/2021 1
G = 0.43
Beam Design 2021A32
1/14/2021 2
= 30.99 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (99.00 + 3)] x (12 in./ft.)3 = 1.99 ft3
Volumespan = N[A x L] = 2 x [16.88 x 99.00] x (12 in./ft.)3 = 1.93 ft3
Total Weight (WT) = ρw x Volumetotal = 30.99 x 1.99 = 61.7 lbs
Self Weight (WS) = ρw x Volumespan = 30.99 x 1.93 = 59.9 lbs
Distributed Self Weight (ws) = = 7.26 plf
450 plf
60 plf
ws = 7.26 plf
8.25 ft.
8.50 ft.
2198.37 lbs
2198.37 lbs
Beam Design 2021A32
1/14/2021 3
Fbx' = (850)(1.15)(1)(1)(1)(1)(1)(1) = 977.5 psi
fb = = 834.5 psi
 fb = 834.5 psi < Fbx' = 977.5 psi  (CSI = 0.85)   ➜  OK
Beam Design 2021A32
1/14/2021 4
fv* = = 73.28 psi
 fv* = 73.28 psi < Fvx' = 167.32 psi  (CSI = 0.44)   ➜  OK
fv = = 94.83 psi
 fv = 94.83 psi < Fvx' = 167.32 psi  (CSI = 0.57)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1300000(0.9)(1)(1) = 1170000 psi
Beam Design 2021A32
1/14/2021 5
ΔLL = = 0.11 in.
(L/d)LL = 99.00 / 0.11 = 879
 ΔLL = 0.11 in = L/879 < L/360   ➜  OK
ΔTL = = 0.13 in.
(L/d)TL = 99.00 / 0.13 = 765
 ΔTL = 0.13 in = L/765 < L/240   ➜  OK
fc⊥ = = 244.3 psi
 fc⊥ = 244.3 psi < Fc⊥x' = 271.35 psi  (CSI = 0.90)   ➜  OK
Beam Design 2021A32
1/14/2021 6
