Species: Western Cedars
Grade: WC SS
Live Load: 100 lbs
Dead Load: 75 lbs
Selfweight: 57.0 lbs
Dist. Selfweight: 4.85 plf
Total Weight: 58.2 lbs
Beam Design 2021A306
5/5/2021 1
WC SS 1000 600 155 425 1000 1100000 400000 0.36
G = 0.36
5/5/2021 2
= 25.18 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (141.00 + 3)] x (12 in./ft.)3 = 2.31 ft3
Volumespan = N[A x L] = 2 x [13.88 x 141.00] x (12 in./ft.)3 = 2.26 ft3
Total Weight (WT) = ρw x Volumetotal = 25.18 x 2.31 = 58.2 lbs
Self Weight (WS) = ρw x Volumespan = 25.18 x 2.26 = 57.0 lbs
Distributed Self Weight (ws) = = 4.85 plf
100 lbs
75 lbs
ws = 4.85 plf
116.62 lbs
116.62 lbs
5/5/2021 3
Fbx' = (1000)(1.15)(1)(1)(1)(1.1)(1)(1) = 1265.0 psi
fb = = 167.7 psi
 fb = 167.7 psi < Fbx' = 1265.0 psi  (CSI = 0.13)   ➜  OK
5/5/2021 4
Fvx' = (155)(1.15)(1)(1)(1) = 178.25 psi
fv* = = 6.07 psi
 fv* = 6.07 psi < Fvx' = 178.25 psi  (CSI = 0.03)   ➜  OK
fv = = 6.27 psi
 fv = 6.27 psi < Fvx' = 178.25 psi  (CSI = 0.04)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1100000(1)(1)(1) = 1100000 psi
5/5/2021 5
ΔLL =   =   = 0.03 in.
(L/d)LL = 141.00 / 0.03 = 5255
 ΔLL = 0.03 in = L/5255 < L/360   ➜  OK
ΔTL =   =   = 0.06 in.
(L/d)TL = 141.00 / 0.06 = 2495
 ΔTL = 0.06 in = L/2495 < L/240   ➜  OK
fc⊥ = = 13.0 psi
 fc⊥ = 13.0 psi < Fc⊥x' = 425.00 psi  (CSI = 0.03)   ➜  OK
5/5/2021 6
