Species: Western Cedars
Grade: WC SS
Live Load: 100 lbs
Dead Load: 75 lbs
Selfweight: 28.5 lbs
Dist. Selfweight: 2.43 plf
Total Weight: 29.1 lbs
Beam Design 2021A305
5/5/2021 1
WC SS 1000 600 155 425 1000 1100000 400000 0.36
G = 0.36
5/5/2021 2
= 25.18 lbs/ft3
Total Weight (WT) = ρw x Volumetotal = 25.18 x 1.16 = 29.1 lbs
Self Weight (WS) = ρw x Volumespan = 25.18 x 1.13 = 28.5 lbs
Distributed Self Weight (ws) = = 2.43 plf
100 lbs
75 lbs
ws = 2.43 plf
102.06 lbs
102.06 lbs
5/5/2021 3
Fbx' = (1000)(1.15)(1)(1)(1)(1.1)(1)(1) = 1265.0 psi
fb = = 311.9 psi
 fb = 311.9 psi < Fbx' = 1265.0 psi  (CSI = 0.25)   ➜  OK
5/5/2021 4
Fvx' = (155)(1.15)(1)(1)(1) = 178.25 psi
fv* = = 10.80 psi
 fv* = 10.80 psi < Fvx' = 178.25 psi  (CSI = 0.06)   ➜  OK
fv = = 11.00 psi
 fv = 11.00 psi < Fvx' = 178.25 psi  (CSI = 0.06)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1100000(1)(1)(1) = 1100000 psi
5/5/2021 5
ΔLL =   =   = 0.05 in.
(L/d)LL = 141.00 / 0.05 = 2627
 ΔLL = 0.05 in = L/2627 < L/360   ➜  OK
ΔTL =   =   = 0.10 in.
(L/d)TL = 141.00 / 0.10 = 1363
 ΔTL = 0.10 in = L/1363 < L/240   ➜  OK
fc⊥ = = 22.7 psi
 fc⊥ = 22.7 psi < Fc⊥x' = 425.00 psi  (CSI = 0.05)   ➜  OK
5/5/2021 6
