Beam Design - Beam Living Room
Size: 4 x 6
Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Live Load: 0 plf
Dead Load: 20 plf
Selfweight: 58.3 lbs
Dist. Selfweight: 4.57 plf
Total Weight: 59.4 lbs
CL Beam Stability Factor 0.989 - - - - -
Beam Design Hans Strandgaard Disney-Camphor
5/1/2021 1
5/1/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (153.00 + 3)] x (12 in./ft.)3 = 1.74 ft3
Volumespan = N[A x L] = 1 x [19.25 x 153.00] x (12 in./ft.)3 = 1.70 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.74 = 59.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.70 = 58.3 lbs
0 plf
20 plf
ws = 4.57 plf
12.75 ft.
12.50 ft.
13.00 ft.
159.72 lbs
159.72 lbs
5/1/2021 3
lu = Unbraced Length = 12.750 ft.
lu/d = = 27.82
le = 1.63lu + 3d = 1.63(153.0) + 3(5.5) = 265.89 in. = 22.16 ft.  (NDS Table 3.3.3)
Rb = = 10.93
 Rb = 10.93 < 50   ➜  OK
5/1/2021 4
FbE = = 5830.16 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(0.9)(1)(1)(1.3)(1)(1) = 1053.00 psi
CL =   = 0.989
Fbx' = (900)(0.9)(1)(1)(0.989)(1.3)(1)(1) = 1041.7 psi
fb = = 339.6 psi
 fb = 339.6 psi < Fbx' = 1041.7 psi  (CSI = 0.33)   ➜  OK
fv* = = 11.33 psi
 fv* = 11.33 psi < Fvx' = 162.00 psi  (CSI = 0.07)   ➜  OK
fv = = 12.21 psi
 fv = 12.21 psi < Fvx' = 162.00 psi  (CSI = 0.08)   ➜  OK
5/1/2021 5
ΔLL = = 0.00 in.
(L/d)LL = 153.00 / 0.00 = ∞
ΔTL = = 0.19 in.
(L/d)TL = 153.00 / 0.19 = 813
 ΔTL = 0.19 in = L/813 < L/240   ➜  OK
fc⊥ = = 15.2 psi
 fc⊥ = 15.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.02)   ➜  OK
5/1/2021 6
