Size: 2.5 x 12
Design Span (L): 12.04 ft.
Clear Span: 11.75 ft.
Total Span: 12.33 ft.
Bearing (lb): 3.5 in.
Live Load: 537 plf
Dead Load: 154 plf
Selfweight: 84.7 lbs
Dist. Selfweight: 7.03 plf
Total Weight: 86.7 lbs
Beam Design 2021A3
1/3/2021 1
b = 2.500 in.
A = 2.500 x 12.000 = 30.00 in.2
Sx = (2.500)(12.000)2/6 = 60.00 in.3
Sy = (2.500)2(12.000)/6 = 12.50 in.3
Ix = (2.500)(12.000)3/12 = 360.00 in.4
Iy = (2.500)3(12.000)/12 = 15.63 in.4
Beam Design 2021A3
1/3/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [30.00 x (144.50 + 3.5)] x (12 in./ft.)3 = 2.57 ft3
Volumespan = N[A x L] = 1 x [30.00 x 144.50] x (12 in./ft.)3 = 2.51 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 2.57 = 86.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 2.51 = 84.7 lbs
Distributed Self Weight (ws) = = 7.03 plf
537 plf
154 plf
  ws = 7.03 plf
12.04 ft.
12.33 ft.
4304.66 lbs
4304.66 lbs
Beam Design 2021A3
1/3/2021 3
lu/d = = 2.00
Rb = = 9.74
 Rb = 9.74 < 50   ➜  OK
Beam Design 2021A3
1/3/2021 4
FbE = = 10745.35 psi
CL =   = 0.983
CL = 0.983 < CV = 1.0
Fbx' = (2400)(1.15)(1)(1)(0.983) = 2714.1 psi
fb = = 2530.5 psi
 fb = 2530.5 psi < Fbx' = 2714.1 psi  (CSI = 0.93)   ➜  OK
fv* = = 175.24 psi
Beam Design 2021A3
1/3/2021 5
 fv* = 175.24 psi < Fvx' = 304.75 psi  (CSI = 0.58)   ➜  OK
fv = = 210.14 psi
 fv = 210.14 psi < Fvx' = 304.75 psi  (CSI = 0.69)   ➜  OK
ΔLL = = 0.39 in.
(L/d)LL = 144.50 / 0.39 = 369
 ΔLL = 0.39 in = L/369 < L/240   ➜  OK
ΔTL = = 0.51 in.
(L/d)TL = 144.50 / 0.51 = 284
 ΔTL = 0.51 in = L/284 < L/180   ➜  OK
Beam Design 2021A3
1/3/2021 6
Ab = b x lb = 2.5 x 3.5 = 8.75 in2
fc⊥ = = 492.0 psi
 fc⊥ = 492.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.76)   ➜  OK
Beam Design 2021A3
1/3/2021 7
