Size: 4 x 8
Design Span (L): 6.75 ft.
Clear Span: 6.50 ft.
Total Span: 7.00 ft.
Live Load: 150 plf
Dead Load: 125 plf
Selfweight: 40.7 lbs
Dist. Selfweight: 6.03 plf
Total Weight: 42.2 lbs
Beam Design 2021A299
5/1/2021 1
5/1/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (81.00 + 3)] x (12 in./ft.)3 = 1.23 ft3
Volumespan = N[A x L] = 1 x [25.38 x 81.00] x (12 in./ft.)3 = 1.19 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.23 = 42.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.19 = 40.7 lbs
150 plf
125 plf
ws = 6.03 plf
6.75 ft.
6.50 ft.
7.00 ft.
983.60 lbs
983.60 lbs
5/1/2021 3
lu/d = = 3.31
Rb = = 5.41
 Rb = 5.41 < 50   ➜  OK
5/1/2021 4
FbE = = 23786.41 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.00)(1)(1)(1.3)(1)(1) = 1170.00 psi
CL =   = 0.997
Fbx' = (900)(1.00)(1)(1)(0.997)(1.3)(1)(1) = 1167.0 psi
fb = = 626.4 psi
 fb = 626.4 psi < Fbx' = 1167.0 psi  (CSI = 0.54)   ➜  OK
fv* = = 46.03 psi
 fv* = 46.03 psi < Fvx' = 180.00 psi  (CSI = 0.26)   ➜  OK
fv = = 56.07 psi
 fv = 56.07 psi < Fvx' = 180.00 psi  (CSI = 0.31)   ➜  OK
5/1/2021 5
ΔLL = = 0.04 in.
(L/d)LL = 81.00 / 0.04 = 2056
 ΔLL = 0.04 in = L/2056 < L/360   ➜  OK
ΔTL = = 0.07 in.
(L/d)TL = 81.00 / 0.07 = 1097
 ΔTL = 0.07 in = L/1097 < L/240   ➜  OK
fc⊥ = = 93.7 psi
 fc⊥ = 93.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.15)   ➜  OK
5/1/2021 6
