Grade: SPF No.2
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: plf
Dead Load: 440 plf
Selfweight: 51.1 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 52.7 lbs
Beam Design 2021A298
4/30/2021 1
4/30/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (93.00 + 3)] x (12 in./ft.)3 = 1.81 ft3
Volumespan = N[A x L] = 3 x [10.88 x 93.00] x (12 in./ft.)3 = 1.76 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.81 = 52.7 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.76 = 51.1 lbs
plf
440 plf
ws = 6.59 plf
7.75 ft.
7.50 ft.
1786.37 lbs
1786.37 lbs
4/30/2021 3
Fbx' = (875)(1.15)(1)(1)(1)(1.2)(1)(1) = 1207.5 psi
fb = = 1020.6 psi
 fb = 1020.6 psi < Fbx' = 1207.5 psi  (CSI = 0.85)   ➜  OK
4/30/2021 4
fv* = = 67.16 psi
 fv* = 67.16 psi < Fvx' = 155.25 psi  (CSI = 0.43)   ➜  OK
fv = = 79.57 psi
 fv = 79.57 psi < Fvx' = 155.25 psi  (CSI = 0.51)   ➜  OK
4/30/2021 5
ΔLL = = 0.00 in.
(L/d)LL = 93.00 / 0.00 = ∞
ΔTL = = 0.18 in.
(L/d)TL = 93.00 / 0.18 = 513
 ΔTL = 0.18 in = L/513 < L/120   ➜  OK
fc⊥ = = 132.3 psi
 fc⊥ = 132.3 psi < Fc⊥x' = 425.00 psi  (CSI = 0.31)   ➜  OK
4/30/2021 6
