Beam Design - EX GR FL JOISTS
Grade: SPF No.2
Design Span (L): 8.75 ft.
Clear Span: 8.50 ft.
Total Span: 9.00 ft.
Live Load: 60 plf
Dead Load: 22.5 plf
Selfweight: 38.5 lbs
Dist. Selfweight: 4.39 plf
Total Weight: 39.6 lbs
Beam Design STEELE LIU 2021-016
4/30/2021 1
4/30/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (105.00 + 3)] x (12 in./ft.)3 = 1.36 ft3
Volumespan = N[A x L] = 2 x [10.88 x 105.00] x (12 in./ft.)3 = 1.32 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.36 = 39.6 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.32 = 38.5 lbs
60 plf
22.5 plf
ws = 4.39 plf
8.75 ft.
8.50 ft.
9.00 ft.
391.03 lbs
391.03 lbs
4/30/2021 3
Fbx' = (875)(1.00)(1)(1)(1)(1.2)(1)(1) = 1050.0 psi
fb = = 379.7 psi
 fb = 379.7 psi < Fbx' = 1050.0 psi  (CSI = 0.36)   ➜  OK
4/30/2021 4
fv* = = 22.60 psi
 fv* = 22.60 psi < Fvx' = 135.00 psi  (CSI = 0.17)   ➜  OK
fv = = 26.22 psi
 fv = 26.22 psi < Fvx' = 135.00 psi  (CSI = 0.19)   ➜  OK
4/30/2021 5
ΔLL = = 0.06 in.
(L/d)LL = 105.00 / 0.06 = 1770
 ΔLL = 0.06 in = L/1770 < L/360   ➜  OK
ΔTL = = 0.09 in.
(L/d)TL = 105.00 / 0.09 = 1222
 ΔTL = 0.09 in = L/1222 < L/240   ➜  OK
fc⊥ = = 43.4 psi
 fc⊥ = 43.4 psi < Fc⊥x' = 425.00 psi  (CSI = 0.10)   ➜  OK
4/30/2021 6
