Grade: SPF No.2
Design Span (L): 12.58 ft.
Clear Span: 12.33 ft.
Total Span: 12.83 ft.
Live Load: 32 plf
Dead Load: 12 plf
Selfweight: 27.6 lbs
Dist. Selfweight: 2.20 plf
Total Weight: 28.2 lbs
Beam Design 2021A295
4/30/2021 1
4/30/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (150.96 + 3)] x (12 in./ft.)3 = 0.97 ft3
Volumespan = N[A x L] = 1 x [10.88 x 150.96] x (12 in./ft.)3 = 0.95 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.97 = 28.2 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.95 = 27.6 lbs
Distributed Self Weight (ws) = = 2.20 plf
32 plf
12 plf
ws = 2.20 plf
12.58 ft.
12.33 ft.
12.83 ft.
296.36 lbs
296.36 lbs
4/30/2021 3
Fbx' = (875)(1.00)(1)(1)(1)(1.2)(1)(1) = 1050.0 psi
fb = = 834.6 psi
 fb = 834.6 psi < Fbx' = 1050.0 psi  (CSI = 0.79)   ➜  OK
4/30/2021 4
fv* = = 36.23 psi
 fv* = 36.23 psi < Fvx' = 135.00 psi  (CSI = 0.27)   ➜  OK
fv = = 40.08 psi
 fv = 40.08 psi < Fvx' = 135.00 psi  (CSI = 0.30)   ➜  OK
4/30/2021 5
ΔLL = = 0.27 in.
(L/d)LL = 150.96 / 0.27 = 558
 ΔLL = 0.27 in = L/558 < L/360   ➜  OK
ΔTL = = 0.39 in.
(L/d)TL = 150.96 / 0.39 = 387
 ΔTL = 0.39 in = L/387 < L/240   ➜  OK
fc⊥ = = 65.9 psi
 fc⊥ = 65.9 psi < Fc⊥x' = 425.00 psi  (CSI = 0.15)   ➜  OK
4/30/2021 6
