Grade: SPF No.2
Design Span (L): 16.00 ft.
Clear Span: 15.75 ft.
Total Span: 16.25 ft.
Live Load: 6.65 plf
Dead Load: 0 plf
Selfweight: 26.7 lbs
Dist. Selfweight: 1.67 plf
Total Weight: 27.1 lbs
Load Duration: 1.60
Beam Design 2021A294
4/28/2021 1
4/28/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (192.00 + 3)] x (12 in./ft.)3 = 0.93 ft3
Volumespan = N[A x L] = 1 x [8.25 x 192.00] x (12 in./ft.)3 = 0.92 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.93 = 27.1 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.92 = 26.7 lbs
6.65 plf
0 plf
ws = 1.67 plf
15.75 ft.
16.25 ft.
67.58 lbs
67.58 lbs
4/28/2021 3
Fbx' = (875)(1.60)(1)(1)(1)(1.3)(1)(1.15) = 2093.0 psi
fb = = 422.3 psi
 fb = 422.3 psi < Fbx' = 2093.0 psi  (CSI = 0.20)   ➜  OK
4/28/2021 4
Fvx' = (135)(1.60)(1)(1)(1) = 216.00 psi
fv* = = 11.40 psi
 fv* = 11.40 psi < Fvx' = 216.00 psi  (CSI = 0.05)   ➜  OK
fv = = 12.10 psi
 fv = 12.10 psi < Fvx' = 216.00 psi  (CSI = 0.06)   ➜  OK
4/28/2021 5
ΔLL = = 0.34 in.
(L/d)LL = 192.00 / 0.34 = 570
 ΔLL = 0.34 in = L/570 < L/360   ➜  OK
ΔTL = = 0.42 in.
(L/d)TL = 192.00 / 0.42 = 456
 ΔTL = 0.42 in = L/456 < L/240   ➜  OK
fc⊥ = = 15.0 psi
 fc⊥ = 15.0 psi < Fc⊥x' = 425.00 psi  (CSI = 0.04)   ➜  OK
4/28/2021 6
