Grade: SP DSS
Size: 4 x 10
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 180 plf
Dead Load: 60 plf
Selfweight: 132.2 lbs
Dist. Selfweight: 8.39 plf
Total Weight: 134.3 lbs
CF Size Factor 1.1 1 - 1 - -
Beam Design 2021A292
4/27/2021 1
4/27/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [32.38 x (189.00 + 3)] x (12 in./ft.)3 = 3.60 ft3
Volumespan = N[A x L] = 1 x [32.38 x 189.00] x (12 in./ft.)3 = 3.54 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 3.60 = 134.3 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 3.54 = 132.2 lbs
Distributed Self Weight (ws) = = 8.39 plf
180 plf
60 plf
ws = 8.39 plf
15.75 ft.
15.50 ft.
1987.14 lbs
1987.14 lbs
4/27/2021 3
Fbx' = (1950)(1.15)(1)(1)(1)(1.1)(1)(1) = 2466.8 psi
fb = = 1851.8 psi
 fb = 1851.8 psi < Fbx' = 2466.8 psi  (CSI = 0.75)   ➜  OK
4/27/2021 4
fv* = = 81.76 psi
 fv* = 81.76 psi < Fvx' = 201.25 psi  (CSI = 0.41)   ➜  OK
fv = = 90.63 psi
 fv = 90.63 psi < Fvx' = 201.25 psi  (CSI = 0.45)   ➜  OK
4/27/2021 5
ΔLL = = 0.57 in.
(L/d)LL = 189.00 / 0.57 = 333
 ΔLL = 0.57 in = L/333 < L/180   ➜  OK
ΔTL = = 0.78 in.
(L/d)TL = 189.00 / 0.78 = 241
 ΔTL = 0.78 in = L/241 < L/120   ➜  OK
fc⊥ = = 189.3 psi
 fc⊥ = 189.3 psi < Fc⊥x' = 660.00 psi  (CSI = 0.29)   ➜  OK
4/27/2021 6
