Beam Design - Dinning Room Support Beam
Design Span (L): 11.25 ft.
Clear Span: 11.00 ft.
Total Span: 11.50 ft.
Live Load: 1350 lbs
Dead Load: 720 lbs
Selfweight: 74.2 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 75.8 lbs
Beam Design Robert Schmaltz 85 Clark St 2021A29
1/13/2021 1
1/13/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (135.00 + 3)] x (12 in./ft.)3 = 2.22 ft3
Volumespan = N[A x L] = 2 x [13.88 x 135.00] x (12 in./ft.)3 = 2.17 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.22 = 75.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.17 = 74.2 lbs
1350 lbs
720 lbs
ws = 6.59 plf
11.25 ft.
11.00 ft.
1072.90 lbs
1072.90 lbs
1/13/2021 3
fb = = 1662.3 psi
 fb = 1662.3 psi > Fbx' = 1138.5 psi  (CSI = 1.46)   ➜  NG
1/13/2021 4
fv* = = 57.68 psi
 fv* = 57.68 psi < Fvx' = 207.00 psi  (CSI = 0.28)   ➜  OK
fv = = 57.95 psi
 fv = 57.95 psi < Fvx' = 207.00 psi  (CSI = 0.28)   ➜  OK
1/13/2021 5
ΔLL =   =   = 0.22 in.
(L/d)LL = 135.00 / 0.22 = 618
 ΔLL = 0.22 in = L/618 < L/360   ➜  OK
ΔTL =   =   = 0.34 in.
(L/d)TL = 135.00 / 0.34 = 394
 ΔTL = 0.34 in = L/394 < L/240   ➜  OK
fc⊥ = = 119.2 psi
 fc⊥ = 119.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.19)   ➜  OK
1/13/2021 6
