Size: 3.125 x 12
Design Span (L): 17.75 ft.
Clear Span: 17.50 ft.
Total Span: 18.00 ft.
Selfweight: 468.2 lbs
Dist. Selfweight: 26.38 plf
Total Weight: 474.8 lbs
Beam Design 2021A286
4/24/2021 1
b = 3.125 in.
4/24/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [37.50 x (213.00 + 3)] x (12 in./ft.)3 = 14.06 ft3
Volumespan = N[A x L] = 3 x [37.50 x 213.00] x (12 in./ft.)3 = 13.87 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 14.06 = 474.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 13.87 = 468.2 lbs
Distributed Self Weight (ws) = = 26.38 plf
  ws = 26.38 plf
17.75 ft.
17.50 ft.
18.00 ft.
1812.38 lbs
1812.38 lbs
4/24/2021 3
lu = Unbraced Length = 17.750 ft.
lu/d = = 17.75
le = 1.63lu + 3d = 1.63(213.0) + 3(12) = 383.19 in. = 31.93 ft.  (NDS Table 3.3.3)
Rb = = 7.23
 Rb = 7.23 < 50   ➜  OK
4/24/2021 4
FbE = = 19496.08 psi
CL =   = 0.992
CL = 0.992 < CV = 1.0
Fbx' = (2400)(1.15)(1)(1)(0.992) = 2737.6 psi
fb = = 423.0 psi
 fb = 423.0 psi < Fbx' = 2737.6 psi  (CSI = 0.15)   ➜  OK
fv* = = 21.14 psi
4/24/2021 5
 fv* = 21.14 psi < Fvx' = 304.75 psi  (CSI = 0.07)   ➜  OK
fv = = 23.83 psi
 fv = 23.83 psi < Fvx' = 304.75 psi  (CSI = 0.08)   ➜  OK
ΔLL = = 0.09 in.
(L/d)LL = 213.00 / 0.09 = 2317
 ΔLL = 0.09 in = L/2317 < L/360   ➜  OK
ΔTL = = 0.19 in.
(L/d)TL = 213.00 / 0.19 = 1151
 ΔTL = 0.19 in = L/1151 < L/240   ➜  OK
4/24/2021 6
fc⊥ = = 64.4 psi
 fc⊥ = 64.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.10)   ➜  OK
4/24/2021 7
