Design Span (L): 5.00 ft.
Clear Span: 4.85 ft.
Total Span: 5.15 ft.
Bearing (lb): 1.75 in.
Live Load: 280 plf
Dead Load: 70 plf
Selfweight: 22.1 lbs
Dist. Selfweight: 4.42 plf
Total Weight: 22.7 lbs
Beam Design 2021A284
4/23/2021 1
4/23/2021 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (60.00 + 1.75)] x (12 in./ft.)3 = 0.59 ft3
Volumespan = N[A x L] = 2 x [8.25 x 60.00] x (12 in./ft.)3 = 0.57 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 0.59 = 22.7 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 0.57 = 22.1 lbs
Distributed Self Weight (ws) = = 4.42 plf
280 plf
70 plf
ws = 4.42 plf
5.00 ft.
4.85 ft.
5.15 ft.
911.90 lbs
911.90 lbs
4/23/2021 3
lu = Unbraced Length = 5 ft.
lu/d = = 10.91
le = 1.63lu + 3d = 1.63(60.0) + 3(5.5) = 114.30 in. = 9.52 ft.  (NDS Table 3.3.3)
Rb = = 8.36
 Rb = 8.36 < 50   ➜  OK
4/23/2021 4
Eminy' = Eminy(CM)(Ct)(Ci) = 510000(0.9)(1)(1) = 459000 psi
FbE = = 7885.47 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1000)(1.00)(1)(1)(1)(1)(1) = 1000.00 psi
CL =   = 0.993
Fbx' = (1000)(1.00)(1)(1)(0.993)(1)(1)(1) = 992.8 psi
fb = = 878.7 psi
 fb = 878.7 psi < Fbx' = 992.8 psi  (CSI = 0.89)   ➜  OK
fv* = = 65.78 psi
 fv* = 65.78 psi < Fvx' = 169.75 psi  (CSI = 0.39)   ➜  OK
fv = = 80.55 psi
 fv = 80.55 psi < Fvx' = 169.75 psi  (CSI = 0.47)   ➜  OK
4/23/2021 5
ΔLL = = 0.08 in.
(L/d)LL = 60.00 / 0.08 = 799
 ΔLL = 0.08 in = L/799 < L/360   ➜  OK
ΔTL = = 0.10 in.
(L/d)TL = 60.00 / 0.10 = 631
 ΔTL = 0.10 in = L/631 < L/240   ➜  OK
Ab = b x lb = 1.5 x 1.75 = 2.63 in2
fc⊥ = = 173.7 psi
 fc⊥ = 173.7 psi < Fc⊥x' = 378.55 psi  (CSI = 0.46)   ➜  OK
4/23/2021 6
