Grade: SP DSS
Design Span (L): 6.00 ft.
Clear Span: 5.75 ft.
Total Span: 6.25 ft.
Live Load: 320 plf
Dead Load: 80 plf
Selfweight: 26.5 lbs
Dist. Selfweight: 4.42 plf
Total Weight: 27.6 lbs
CL Beam Stability Factor 0.986 - - - - -
Beam Design 2021A281
4/23/2021 1
SP DSS 2400 1650 175 660 1900 1900000 690000 0.55
4/23/2021 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (72.00 + 3)] x (12 in./ft.)3 = 0.72 ft3
Volumespan = N[A x L] = 2 x [8.25 x 72.00] x (12 in./ft.)3 = 0.69 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 0.72 = 27.6 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 0.69 = 26.5 lbs
Distributed Self Weight (ws) = = 4.42 plf
320 plf
80 plf
ws = 4.42 plf
5.75 ft.
6.25 ft.
1263.82 lbs
1263.82 lbs
4/23/2021 3
lu = Unbraced Length = 6 ft.
lu/d = = 13.09
le = 1.63lu + 3d = 1.63(72.0) + 3(5.5) = 133.86 in. = 11.15 ft.  (NDS Table 3.3.3)
Rb = = 9.04
 Rb = 9.04 < 50   ➜  OK
4/23/2021 4
Eminy' = Eminy(CM)(Ct)(Ci) = 690000(0.9)(1)(1) = 621000 psi
FbE = = 9109.65 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (2400)(1.00)(0.85)(1)(1)(1)(1) = 2040.00 psi
CL =   = 0.986
Fbx' = (2400)(1.00)(0.85)(1)(0.986)(1)(1)(1) = 2011.5 psi
fb = = 1443.9 psi
 fb = 1443.9 psi < Fbx' = 2011.5 psi  (CSI = 0.72)   ➜  OK
fv* = = 93.45 psi
 fv* = 93.45 psi < Fvx' = 169.75 psi  (CSI = 0.55)   ➜  OK
fv = = 110.30 psi
 fv = 110.30 psi < Fvx' = 169.75 psi  (CSI = 0.65)   ➜  OK
4/23/2021 5
ΔLL = = 0.13 in.
(L/d)LL = 72.00 / 0.13 = 549
 ΔLL = 0.13 in = L/549 < L/360   ➜  OK
ΔTL = = 0.17 in.
(L/d)TL = 72.00 / 0.17 = 434
 ΔTL = 0.17 in = L/434 < L/240   ➜  OK
Fc⊥x' = (660)(0.67)(1)(1) = 442.20 psi
fc⊥ = = 140.4 psi
 fc⊥ = 140.4 psi < Fc⊥x' = 442.20 psi  (CSI = 0.32)   ➜  OK
4/23/2021 6
