Grade: SPF No.2
Design Span (L): 5.00 ft.
Clear Span: 4.75 ft.
Total Span: 5.25 ft.
Live Load: 320 plf
Dead Load: 80 plf
Selfweight: 17.4 lbs
Dist. Selfweight: 3.48 plf
Total Weight: 18.2 lbs
Beam Design 2021A279
4/23/2021 1
4/23/2021 2
= 30.34 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (60.00 + 3)] x (12 in./ft.)3 = 0.60 ft3
Volumespan = N[A x L] = 2 x [8.25 x 60.00] x (12 in./ft.)3 = 0.57 ft3
Total Weight (WT) = ρw x Volumetotal = 30.34 x 0.60 = 18.2 lbs
Self Weight (WS) = ρw x Volumespan = 30.34 x 0.57 = 17.4 lbs
Distributed Self Weight (ws) = = 3.48 plf
320 plf
80 plf
ws = 3.48 plf
5.00 ft.
4.75 ft.
5.25 ft.
1059.12 lbs
1059.12 lbs
4/23/2021 3
lu = Unbraced Length = 5 ft.
lu/d = = 10.91
le = 1.63lu + 3d = 1.63(60.0) + 3(5.5) = 114.30 in. = 9.52 ft.  (NDS Table 3.3.3)
Rb = = 8.36
 Rb = 8.36 < 50   ➜  OK
4/23/2021 4
Eminy' = Eminy(CM)(Ct)(Ci) = 510000(0.9)(1)(1) = 459000 psi
FbE = = 7885.47 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (875)(1.00)(1)(1)(1.3)(1)(1) = 1137.50 psi
CL =   = 0.992
Fbx' = (875)(1.00)(1)(1)(0.992)(1.3)(1)(1) = 1128.1 psi
fb = = 1000.4 psi
 fb = 1000.4 psi < Fbx' = 1128.1 psi  (CSI = 0.89)   ➜  OK
Fvx' = (135)(1.00)(0.97)(1)(1) = 130.95 psi
fv* = = 74.89 psi
 fv* = 74.89 psi < Fvx' = 130.95 psi  (CSI = 0.57)   ➜  OK
fv = = 91.70 psi
 fv = 91.70 psi < Fvx' = 130.95 psi  (CSI = 0.70)   ➜  OK
4/23/2021 5
ΔLL = = 0.09 in.
(L/d)LL = 60.00 / 0.09 = 699
 ΔLL = 0.09 in = L/699 < L/360   ➜  OK
ΔTL = = 0.11 in.
(L/d)TL = 60.00 / 0.11 = 554
 ΔTL = 0.11 in = L/554 < L/240   ➜  OK
fc⊥ = = 117.7 psi
 fc⊥ = 117.7 psi < Fc⊥x' = 284.75 psi  (CSI = 0.41)   ➜  OK
4/23/2021 6
