Grade: SP No.1
Size: 4 x 12
Design Span (L): 19.54 ft.
Clear Span: 19.08 ft.
Total Span: 20.00 ft.
Bearing (lb): 5.5 in.
Live Load: 200 plf
Dead Load: 100 plf
Selfweight: 398.9 lbs
Dist. Selfweight: 20.41 plf
Total Weight: 408.3 lbs
CF Size Factor 1.1 1 - 1 - -
Beam Design 2021A277
4/23/2021 1
4/23/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [39.38 x (234.50 + 5.5)] x (12 in./ft.)3 = 10.94 ft3
Volumespan = N[A x L] = 2 x [39.38 x 234.50] x (12 in./ft.)3 = 10.69 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 10.94 = 408.3 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 10.69 = 398.9 lbs
Distributed Self Weight (ws) = = 20.41 plf
200 plf
ws = 20.41 plf
19.54 ft.
19.08 ft.
3204.20 lbs
3204.20 lbs
4/23/2021 3
Fbx' = (1000)(1.15)(1)(1)(1)(1.1)(1)(1) = 1265.0 psi
fb = = 1243.1 psi
 fb = 1243.1 psi < Fbx' = 1265.0 psi  (CSI = 0.98)   ➜  OK
4/23/2021 4
fv* = = 53.91 psi
 fv* = 53.91 psi < Fvx' = 201.25 psi  (CSI = 0.27)   ➜  OK
fv = = 59.63 psi
 fv = 59.63 psi < Fvx' = 201.25 psi  (CSI = 0.30)   ➜  OK
4/23/2021 5
ΔLL = = 0.49 in.
(L/d)LL = 234.50 / 0.49 = 475
 ΔLL = 0.49 in = L/475 < L/180   ➜  OK
ΔTL = = 0.79 in.
(L/d)TL = 234.50 / 0.79 = 296
 ΔTL = 0.79 in = L/296 < L/120   ➜  OK
Ab = b x lb = 3.5 x 5.5 = 19.25 in2
fc⊥ = = 83.2 psi
 fc⊥ = 83.2 psi < Fc⊥x' = 565.00 psi  (CSI = 0.15)   ➜  OK
4/23/2021 6
