Grade: 24F-V3 1.8E SP/SP
Size: 3 x 16.5
Design Span (L): 18.25 ft.
Clear Span: 18.00 ft.
Total Span: 18.50 ft.
Selfweight: 231.4 lbs
Dist. Selfweight: 12.68 plf
Total Weight: 234.6 lbs
Beam Design REA
4/18/2021 1
b = 3.000 in.
d = 16.500 in.
A = 3.000 x 16.500 = 49.50 in.2
Sx = (3.000)(16.500)2/6 = 136.13 in.3
Sy = (3.000)2(16.500)/6 = 24.75 in.3
Ix = (3.000)(16.500)3/12 = 1123.03 in.4
Iy = (3.000)3(16.500)/12 = 37.13 in.4
Beam Design REA
4/18/2021 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [49.50 x (219.00 + 3)] x (12 in./ft.)3 = 6.36 ft3
Volumespan = N[A x L] = 1 x [49.50 x 219.00] x (12 in./ft.)3 = 6.27 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 6.36 = 234.6 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 6.27 = 231.4 lbs
Distributed Self Weight (ws) = = 12.68 plf
  ws = 12.68 plf
18.25 ft.
18.00 ft.
18.50 ft.
1736.05 lbs
1736.05 lbs
Beam Design REA
4/18/2021 3
fb = = 688.8 psi
 fb = 688.8 psi < Fbx' = 2400.0 psi  (CSI = 0.29)   ➜  OK
Beam Design REA
4/18/2021 4
fv* = = 44.08 psi
 fv* = 44.08 psi < Fvx' = 300.00 psi  (CSI = 0.15)   ➜  OK
fv = = 51.90 psi
 fv = 51.90 psi < Fvx' = 300.00 psi  (CSI = 0.17)   ➜  OK
Beam Design REA
4/18/2021 5
ΔLL = = 0.12 in.
(L/d)LL = 219.00 / 0.12 = 1774
 ΔLL = 0.12 in = L/1774 < L/360   ➜  OK
ΔTL = = 0.23 in.
(L/d)TL = 219.00 / 0.23 = 945
 ΔTL = 0.23 in = L/945 < L/240   ➜  OK
Ab = b x lb = 3 x 3 = 9.00 in2
fc⊥ = = 192.9 psi
 fc⊥ = 192.9 psi < Fc⊥x' = 740.00 psi  (CSI = 0.26)   ➜  OK
Beam Design REA
4/18/2021 6
