Grade: SP SS
Design Span (L): 21.45 ft.
Clear Span: 21.20 ft.
Total Span: 21.70 ft.
Live Load: 40 plf
Dead Load: 15 plf
Selfweight: 93.8 lbs
Dist. Selfweight: 4.37 plf
Total Weight: 94.9 lbs
Beam Design 2021A269
4/18/2021 1
SP SS 1600 1100 175 565 1650 1800000 660000 0.55
4/18/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (257.40 + 3)] x (12 in./ft.)3 = 2.54 ft3
Volumespan = N[A x L] = 1 x [16.88 x 257.40] x (12 in./ft.)3 = 2.51 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 2.54 = 94.9 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.51 = 93.8 lbs
40 plf
15 plf
ws = 4.37 plf
21.45 ft.
21.20 ft.
21.70 ft.
644.21 lbs
644.21 lbs
4/18/2021 3
Fbx' = (1600)(1.00)(1)(1)(1)(1)(1)(1) = 1600.0 psi
fb = = 1295.1 psi
 fb = 1295.1 psi < Fbx' = 1600.0 psi  (CSI = 0.81)   ➜  OK
4/18/2021 4
fv* = = 51.66 psi
 fv* = 51.66 psi < Fvx' = 175.00 psi  (CSI = 0.30)   ➜  OK
fv = = 56.60 psi
 fv = 56.60 psi < Fvx' = 175.00 psi  (CSI = 0.32)   ➜  OK
4/18/2021 5
ΔLL = = 0.59 in.
(L/d)LL = 257.40 / 0.59 = 433
 ΔLL = 0.59 in = L/433 < L/360   ➜  OK
ΔTL = = 0.88 in.
(L/d)TL = 257.40 / 0.88 = 292
 ΔTL = 0.88 in = L/292 < L/240   ➜  OK
fc⊥ = = 143.2 psi
 fc⊥ = 143.2 psi < Fc⊥x' = 565.00 psi  (CSI = 0.25)   ➜  OK
4/18/2021 6
