Grade: DF No.1
Design Span (L): 16.45 ft.
Clear Span: 16.20 ft.
Total Span: 16.70 ft.
Live Load: 27 plf
Dead Load: 27 plf
Selfweight: 65.9 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 66.9 lbs
Beam Design 2021A268
4/18/2021 1
4/18/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (197.40 + 3)] x (12 in./ft.)3 = 1.96 ft3
Volumespan = N[A x L] = 1 x [16.88 x 197.40] x (12 in./ft.)3 = 1.93 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.96 = 66.9 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.93 = 65.9 lbs
27 plf
27 plf
ws = 4.01 plf
16.45 ft.
16.20 ft.
16.70 ft.
484.37 lbs
484.37 lbs
4/18/2021 3
fb = = 744.2 psi
 fb = 744.2 psi < Fbx' = 1150.0 psi  (CSI = 0.65)   ➜  OK
4/18/2021 4
fv* = = 37.58 psi
 fv* = 37.58 psi < Fvx' = 207.00 psi  (CSI = 0.18)   ➜  OK
fv = = 42.41 psi
 fv = 42.41 psi < Fvx' = 207.00 psi  (CSI = 0.20)   ➜  OK
4/18/2021 5
ΔLL = = 0.15 in.
(L/d)LL = 197.40 / 0.15 = 1343
 ΔLL = 0.15 in = L/1343 < L/180   ➜  OK
ΔTL = = 0.32 in.
(L/d)TL = 197.40 / 0.32 = 625
 ΔTL = 0.32 in = L/625 < L/120   ➜  OK
fc⊥ = = 107.6 psi
 fc⊥ = 107.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.17)   ➜  OK
4/18/2021 6
