Size: 3.125 x 12
Design Span (L): 4.08 ft.
Clear Span: 3.92 ft.
Total Span: 4.25 ft.
Bearing (lb): 2 in.
Live Load: 800 plf
Dead Load: 96 plf
Selfweight: 35.9 lbs
Dist. Selfweight: 8.79 plf
Total Weight: 37.4 lbs
Beam Design 2021A265
4/16/2021 1
b = 3.125 in.
4/16/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [37.50 x (49.00 + 2)] x (12 in./ft.)3 = 1.11 ft3
Volumespan = N[A x L] = 1 x [37.50 x 49.00] x (12 in./ft.)3 = 1.06 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 1.11 = 37.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 1.06 = 35.9 lbs
800 plf
96 plf
  ws = 8.79 plf
4.08 ft.
3.92 ft.
4.25 ft.
1922.53 lbs
1922.53 lbs
4/16/2021 3
fb = = 301.7 psi
 fb = 301.7 psi < Fbx' = 2760.0 psi  (CSI = 0.11)   ➜  OK
4/16/2021 4
fv* = = 37.69 psi
 fv* = 37.69 psi < Fvx' = 304.75 psi  (CSI = 0.12)   ➜  OK
fv = = 73.89 psi
 fv = 73.89 psi < Fvx' = 304.75 psi  (CSI = 0.24)   ➜  OK
4/16/2021 5
ΔLL = = 0.01 in.
(L/d)LL = 49.00 / 0.01 = 7933
 ΔLL = 0.01 in = L/7933 < L/180   ➜  OK
ΔTL = = 0.01 in.
(L/d)TL = 49.00 / 0.01 = 7015
 ΔTL = 0.01 in = L/7015 < L/120   ➜  OK
Ab = b x lb = 3.125 x 2 = 6.25 in2
fc⊥ = = 307.6 psi
 fc⊥ = 307.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.47)   ➜  OK
4/16/2021 6
