Species: Hem-Fir
Grade: HF Stud
Design Span (L): 18.00 ft.
Clear Span: 17.75 ft.
Total Span: 18.25 ft.
Live Load: 42.05 plf
Dead Load: 5 plf
Selfweight: 130.7 lbs
Dist. Selfweight: 7.26 plf
Total Weight: 132.5 lbs
CL Beam Stability Factor 0.894 - - - - -
Beam Design Richard Kostecki 2021A262
4/15/2021 1
HF Stud 675 400 150 405 800 1200000 440000 0.43
G = 0.43
4/15/2021 2
= 30.99 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (216.00 + 3)] x (12 in./ft.)3 = 4.28 ft3
Volumespan = N[A x L] = 2 x [16.88 x 216.00] x (12 in./ft.)3 = 4.22 ft3
Total Weight (WT) = ρw x Volumetotal = 30.99 x 4.28 = 132.5 lbs
Self Weight (WS) = ρw x Volumespan = 30.99 x 4.22 = 130.7 lbs
Distributed Self Weight (ws) = = 7.26 plf
42.05 plf
5 plf
ws = 7.26 plf
18.00 ft.
17.75 ft.
18.25 ft.
495.60 lbs
495.60 lbs
4/15/2021 3
lu = Unbraced Length = 18 ft.
lu/d = = 19.20
le = 1.63lu + 3d = 1.63(216.0) + 3(11.25) = 385.83 in. = 32.15 ft.  (NDS Table 3.3.3)
Rb = = 21.96
 Rb = 21.96 < 50   ➜  OK
4/15/2021 4
Eminy' = Eminy(CM)(Ct)(Ci) = 440000(0.9)(1)(1) = 396000 psi
FbE = = 985.30 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (675)(1.15)(1)(1)(1)(1)(1) = 776.25 psi
CL =   = 0.894
Fbx' = (675)(1.15)(1)(1)(0.894)(1)(1)(1) = 693.7 psi
fb = = 417.1 psi
 fb = 417.1 psi < Fbx' = 693.7 psi  (CSI = 0.60)   ➜  OK
fv* = = 19.46 psi
 fv* = 19.46 psi < Fvx' = 167.32 psi  (CSI = 0.12)   ➜  OK
fv = = 21.73 psi
 fv = 21.73 psi < Fvx' = 167.32 psi  (CSI = 0.13)   ➜  OK
4/15/2021 5
Ex' = Ex(CM)(Ct)(Ci) = 1200000(0.9)(1)(1) = 1080000 psi
ΔLL = = 0.26 in.
(L/d)LL = 216.00 / 0.26 = 836
 ΔLL = 0.26 in = L/836 < L/360   ➜  OK
ΔTL = = 0.33 in.
(L/d)TL = 216.00 / 0.33 = 647
 ΔTL = 0.33 in = L/647 < L/240   ➜  OK
fc⊥ = = 55.1 psi
 fc⊥ = 55.1 psi < Fc⊥x' = 271.35 psi  (CSI = 0.20)   ➜  OK
4/15/2021 6
