Size: 3.125 x 12
Design Span (L): 4.08 ft.
Clear Span: 3.92 ft.
Total Span: 4.25 ft.
Bearing (lb): 2 in.
Live Load: 800 plf
Dead Load: 96 plf
Selfweight: 37.7 lbs
Dist. Selfweight: 9.24 plf
Total Weight: 39.3 lbs
Beam Design 2021A258
4/14/2021 1
b = 3.125 in.
4/14/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [37.50 x (49.00 + 2)] x (12 in./ft.)3 = 1.11 ft3
Volumespan = N[A x L] = 1 x [37.50 x 49.00] x (12 in./ft.)3 = 1.06 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 1.11 = 39.3 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 1.06 = 37.7 lbs
Distributed Self Weight (ws) = = 9.24 plf
800 plf
96 plf
  ws = 9.24 plf
4.08 ft.
3.92 ft.
4.25 ft.
1923.48 lbs
1923.48 lbs
4/14/2021 3
Fbx' = (2400)(1.00)(0.8)(1)(1.0) = 1920.0 psi
fb = = 301.8 psi
 fb = 301.8 psi < Fbx' = 1920.0 psi  (CSI = 0.16)   ➜  OK
4/14/2021 4
Fvx' = (265)(1.00)(0.875)(1) = 231.88 psi
fv* = = 37.71 psi
 fv* = 37.71 psi < Fvx' = 231.88 psi  (CSI = 0.16)   ➜  OK
fv = = 73.92 psi
 fv = 73.92 psi < Fvx' = 231.88 psi  (CSI = 0.32)   ➜  OK
4/14/2021 5
ΔLL = = 0.01 in.
(L/d)LL = 49.00 / 0.01 = 6608
 ΔLL = 0.01 in = L/6608 < L/360   ➜  OK
ΔTL = = 0.01 in.
(L/d)TL = 49.00 / 0.01 = 5840
 ΔTL = 0.01 in = L/5840 < L/240   ➜  OK
Ab = b x lb = 3.125 x 2 = 6.25 in2
fc⊥ = = 307.8 psi
 fc⊥ = 307.8 psi < Fc⊥x' = 344.50 psi  (CSI = 0.89)   ➜  OK
4/14/2021 6
