Grade: SP No.1
Design Span (L): 10.16 ft.
Clear Span: 9.79 ft.
Total Span: 10.54 ft.
Bearing (lb): 4.5 in.
Live Load: 40 plf
Dead Load: 10 plf
Selfweight: 57.3 lbs
Dist. Selfweight: 5.64 plf
Total Weight: 59.4 lbs
Beam Design 2021A255
4/13/2021 1
SP No.1 1250 800 175 565 1500 1600000 580000 0.55
4/13/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (121.98 + 4.5)] x (12 in./ft.)3 = 1.59 ft3
Volumespan = N[A x L] = 2 x [10.88 x 121.98] x (12 in./ft.)3 = 1.54 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.59 = 59.4 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.54 = 57.3 lbs
40 plf
10 plf
ws = 5.64 plf
10.16 ft.
9.79 ft.
10.54 ft.
293.21 lbs
293.21 lbs
4/13/2021 3
fb = = 328.1 psi
 fb = 328.1 psi < Fbx' = 1437.5 psi  (CSI = 0.23)   ➜  OK
4/13/2021 4
fv* = = 17.18 psi
 fv* = 17.18 psi < Fvx' = 201.25 psi  (CSI = 0.09)   ➜  OK
fv = = 19.50 psi
 fv = 19.50 psi < Fvx' = 201.25 psi  (CSI = 0.10)   ➜  OK
4/13/2021 5
ΔLL = = 0.06 in.
(L/d)LL = 121.98 / 0.06 = 1935
 ΔLL = 0.06 in = L/1935 < L/360   ➜  OK
ΔTL = = 0.09 in.
(L/d)TL = 121.98 / 0.09 = 1391
 ΔTL = 0.09 in = L/1391 < L/240   ➜  OK
Ab = b x lb = 1.5 x 4.5 = 6.75 in2
fc⊥ = = 21.7 psi
 fc⊥ = 21.7 psi < Fc⊥x' = 565.00 psi  (CSI = 0.04)   ➜  OK
4/13/2021 6
