Size: 4 x 6
Design Span (L): 7.25 ft.
Clear Span: 7.00 ft.
Total Span: 7.50 ft.
Live Load: 80 plf
Dead Load: 40 plf
Selfweight: 33.1 lbs
Dist. Selfweight: 4.57 plf
Total Weight: 34.3 lbs
Orientation: Horizontal
Beam Design 2021A253
4/13/2021 1
4/13/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (87.00 + 3)] x (12 in./ft.)3 = 1.00 ft3
Volumespan = N[A x L] = 1 x [19.25 x 87.00] x (12 in./ft.)3 = 0.97 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.00 = 34.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.97 = 33.1 lbs
80 plf
40 plf
ws = 4.57 plf
7.25 ft.
7.00 ft.
7.50 ft.
467.15 lbs
467.15 lbs
4/13/2021 3
Fby' = (900)(1.15)(1)(1)(1)(1.3)(1.05)(1)(1) = 1412.8 psi
fb = = 874.7 psi
 fb = 874.7 psi < Fby' = 1412.8 psi  (CSI = 0.62)   ➜  OK
4/13/2021 4
fv* = = 32.36 psi
 fv* = 32.36 psi < Fvy' = 207.00 psi  (CSI = 0.16)   ➜  OK
fv = = 35.19 psi
 fv = 35.19 psi < Fvy' = 207.00 psi  (CSI = 0.17)   ➜  OK
4/13/2021 5
ΔLL = = 0.16 in.
(L/d)LL = 87.00 / 0.16 = 550
 ΔLL = 0.16 in = L/550 < L/360   ➜  OK
ΔTL = = 0.25 in.
(L/d)TL = 87.00 / 0.25 = 353
 ΔTL = 0.25 in = L/353 < L/240   ➜  OK
Ab = d x lb = 5.5 x 3 = 16.50 in2
fc⊥ = = 28.3 psi
 fc⊥ = 28.3 psi < Fc⊥y' = 625.00 psi  (CSI = 0.05)   ➜  OK
4/13/2021 6
