Grade: SPF No.2
Design Span (L): 12.25 ft.
Clear Span: 12.00 ft.
Total Span: 12.50 ft.
Live Load: 310 plf
Dead Load: 78 plf
Selfweight: 125.3 lbs
Dist. Selfweight: 10.23 plf
Total Weight: 127.9 lbs
Beam Design 2021A252
4/12/2021 1
4/12/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (147.00 + 3)] x (12 in./ft.)3 = 4.39 ft3
Volumespan = N[A x L] = 3 x [16.88 x 147.00] x (12 in./ft.)3 = 4.31 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 4.39 = 127.9 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 4.31 = 125.3 lbs
Distributed Self Weight (ws) = = 10.23 plf
310 plf
78 plf
ws = 10.23 plf
12.25 ft.
12.50 ft.
2488.94 lbs
2488.94 lbs
4/12/2021 3
fb = = 944.3 psi
 fb = 944.3 psi < Fbx' = 1006.2 psi  (CSI = 0.94)   ➜  OK
4/12/2021 4
fv* = = 61.21 psi
 fv* = 61.21 psi < Fvx' = 155.25 psi  (CSI = 0.39)   ➜  OK
fv = = 72.27 psi
 fv = 72.27 psi < Fvx' = 155.25 psi  (CSI = 0.47)   ➜  OK
4/12/2021 5
ΔLL = = 0.21 in.
(L/d)LL = 147.00 / 0.21 = 700
 ΔLL = 0.21 in = L/700 < L/360   ➜  OK
ΔTL = = 0.27 in.
(L/d)TL = 147.00 / 0.27 = 545
 ΔTL = 0.27 in = L/545 < L/240   ➜  OK
fc⊥ = = 184.4 psi
 fc⊥ = 184.4 psi < Fc⊥x' = 425.00 psi  (CSI = 0.43)   ➜  OK
4/12/2021 6
