Grade: SPF No.2
Design Span (L): 11.25 ft.
Clear Span: 11.00 ft.
Total Span: 11.50 ft.
Live Load: 53.2 plf
Dead Load: 13 plf
Selfweight: 31.5 lbs
Dist. Selfweight: 2.80 plf
Total Weight: 32.2 lbs
Beam Design 2021A250
4/12/2021 1
4/12/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (135.00 + 3)] x (12 in./ft.)3 = 1.11 ft3
Volumespan = N[A x L] = 1 x [13.88 x 135.00] x (12 in./ft.)3 = 1.08 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.11 = 32.2 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.08 = 31.5 lbs
Distributed Self Weight (ws) = = 2.80 plf
53.2 plf
13 plf
ws = 2.80 plf
11.25 ft.
11.00 ft.
396.77 lbs
396.77 lbs
4/12/2021 3
Fbx' = (875)(1.15)(1)(1)(1)(1.1)(1)(1) = 1106.9 psi
fb = = 612.4 psi
 fb = 612.4 psi < Fbx' = 1106.9 psi  (CSI = 0.55)   ➜  OK
4/12/2021 4
fv* = = 36.21 psi
 fv* = 36.21 psi < Fvx' = 155.25 psi  (CSI = 0.23)   ➜  OK
fv = = 41.96 psi
 fv = 41.96 psi < Fvx' = 155.25 psi  (CSI = 0.27)   ➜  OK
4/12/2021 5
ΔLL = = 0.14 in.
(L/d)LL = 135.00 / 0.14 = 975
 ΔLL = 0.14 in = L/975 < L/360   ➜  OK
ΔTL = = 0.18 in.
(L/d)TL = 135.00 / 0.18 = 752
 ΔTL = 0.18 in = L/752 < L/240   ➜  OK
fc⊥ = = 88.2 psi
 fc⊥ = 88.2 psi < Fc⊥x' = 425.00 psi  (CSI = 0.21)   ➜  OK
4/12/2021 6
