Species: Western Cedars
Grade: WC SS
Size: 4 x 12
Design Span (L): 16.46 ft.
Clear Span: 16.00 ft.
Total Span: 16.92 ft.
Bearing (lb): 5.5 in.
Live Load: 30 plf
Dead Load: 20 plf
Selfweight: 118.6 lbs
Dist. Selfweight: 7.21 plf
Total Weight: 121.9 lbs
Load Duration: 1.60
CL Beam Stability Factor 0.679 - - - - -
CF Size Factor 1.1 1 - 1 - -
Beam Design 2021A246
4/9/2021 1
WC SS 1000 600 155 425 1000 1100000 400000 0.36
G = 0.36
4/9/2021 2
= 26.36 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (197.50 + 5.5)] x (12 in./ft.)3 = 4.63 ft3
Volumespan = N[A x L] = 1 x [39.38 x 197.50] x (12 in./ft.)3 = 4.50 ft3
Total Weight (WT) = ρw x Volumetotal = 26.36 x 4.63 = 121.9 lbs
Self Weight (WS) = ρw x Volumespan = 26.36 x 4.50 = 118.6 lbs
Distributed Self Weight (ws) = = 7.21 plf
30 plf
20 plf
ws = 7.21 plf
16.46 ft.
16.92 ft.
483.88 lbs
483.88 lbs
4/9/2021 3
lu = Unbraced Length = 16.458 ft.
lu/d = = 17.56
le = 1.63lu + 3d = 1.63(197.5) + 3(11.25) = 355.67 in. = 29.64 ft.  (NDS Table 3.3.3)
Rb = = 18.07
 Rb = 18.07 < 50   ➜  OK
4/9/2021 4
Eminy' = Eminy(CM)(Ct)(Ci) = 400000(0.9)(1)(1) = 360000 psi
FbE = = 1322.58 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1000)(1.60)(1)(1)(1.1)(1)(1) = 1760.00 psi
CL =   = 0.679
Fbx' = (1000)(1.60)(1)(1)(0.679)(1.1)(1)(1) = 1195.8 psi
fb = = 314.8 psi
 fb = 314.8 psi < Fbx' = 1195.8 psi  (CSI = 0.26)   ➜  OK
Fvx' = (155)(1.60)(0.97)(1)(1) = 240.56 psi
fv* = = 15.89 psi
 fv* = 15.89 psi < Fvx' = 240.56 psi  (CSI = 0.07)   ➜  OK
fv = = 17.93 psi
 fv = 17.93 psi < Fvx' = 240.56 psi  (CSI = 0.07)   ➜  OK
4/9/2021 5
Ex' = Ex(CM)(Ct)(Ci) = 1100000(0.9)(1)(1) = 990000 psi
ΔLL = = 0.12 in.
(L/d)LL = 197.50 / 0.12 = 1640
 ΔLL = 0.12 in = L/1640 < L/360   ➜  OK
ΔTL = = 0.23 in.
(L/d)TL = 197.50 / 0.23 = 860
 ΔTL = 0.23 in = L/860 < L/240   ➜  OK
Ab = b x lb = 3.5 x 5.5 = 19.25 in2
fc⊥ = = 25.1 psi
 fc⊥ = 25.1 psi < Fc⊥x' = 284.75 psi  (CSI = 0.09)   ➜  OK
4/9/2021 6
