Size: 3.5 x 12
Design Span (L): 12.95 ft.
Clear Span: 12.70 ft.
Total Span: 13.20 ft.
Live Load: 217.5 plf
Dead Load: 290 plf
Selfweight: 127.5 lbs
Dist. Selfweight: 9.85 plf
Total Weight: 130.0 lbs
Beam Design 2021A241
4/9/2021 1
4/9/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [42.00 x (155.40 + 3)] x (12 in./ft.)3 = 3.85 ft3
Volumespan = N[A x L] = 1 x [42.00 x 155.40] x (12 in./ft.)3 = 3.78 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.85 = 130.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.78 = 127.5 lbs
217.5 plf
290 plf
  ws = 9.85 plf
12.95 ft.
12.70 ft.
13.20 ft.
3414.49 lbs
3414.49 lbs
4/9/2021 3
fb = = 1549.3 psi
 fb = 1549.3 psi < Fbx' = 2400.0 psi  (CSI = 0.65)   ➜  OK
4/9/2021 4
fv* = = 101.16 psi
 fv* = 101.16 psi < Fvx' = 265.00 psi  (CSI = 0.38)   ➜  OK
fv = = 119.64 psi
 fv = 119.64 psi < Fvx' = 265.00 psi  (CSI = 0.45)   ➜  OK
4/9/2021 5
ΔLL = = 0.15 in.
(L/d)LL = 155.40 / 0.15 = 1024
 ΔLL = 0.15 in = L/1024 < L/360   ➜  OK
ΔTL = = 0.36 in.
(L/d)TL = 155.40 / 0.36 = 431
 ΔTL = 0.36 in = L/431 < L/240   ➜  OK
fc⊥ = = 325.2 psi
 fc⊥ = 325.2 psi < Fc⊥x' = 650.00 psi  (CSI = 0.50)   ➜  OK
4/9/2021 6
