Size: 6.75 x 12
Design Span (L): 13.95 ft.
Clear Span: 13.70 ft.
Total Span: 14.20 ft.
Live Load: 290 plf
Dead Load: 290 plf
Selfweight: 264.9 lbs
Dist. Selfweight: 18.99 plf
Total Weight: 269.7 lbs
Beam Design 2021A239
4/9/2021 1
b = 6.750 in.
A = 6.750 x 12.000 = 81.00 in.2
Sx = (6.750)(12.000)2/6 = 162.00 in.3
Sy = (6.750)2(12.000)/6 = 91.13 in.3
Ix = (6.750)(12.000)3/12 = 972.00 in.4
Iy = (6.750)3(12.000)/12 = 307.55 in.4
4/9/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [81.00 x (167.40 + 3)] x (12 in./ft.)3 = 7.99 ft3
Volumespan = N[A x L] = 1 x [81.00 x 167.40] x (12 in./ft.)3 = 7.85 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.99 = 269.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.85 = 264.9 lbs
Distributed Self Weight (ws) = = 18.99 plf
290 plf
290 plf
  ws = 18.99 plf
13.95 ft.
13.70 ft.
14.20 ft.
4252.83 lbs
4252.83 lbs
4/9/2021 3
fb = = 1079.3 psi
 fb = 1079.3 psi < Fbx' = 2400.0 psi  (CSI = 0.45)   ➜  OK
4/9/2021 4
fv* = = 66.28 psi
 fv* = 66.28 psi < Fvx' = 265.00 psi  (CSI = 0.25)   ➜  OK
fv = = 77.37 psi
 fv = 77.37 psi < Fvx' = 265.00 psi  (CSI = 0.29)   ➜  OK
4/9/2021 5
ΔLL = = 0.14 in.
(L/d)LL = 167.40 / 0.14 = 1185
 ΔLL = 0.14 in = L/1185 < L/240   ➜  OK
ΔTL = = 0.29 in.
(L/d)TL = 167.40 / 0.29 = 574
 ΔTL = 0.29 in = L/574 < L/180   ➜  OK
fc⊥ = = 210.0 psi
 fc⊥ = 210.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.32)   ➜  OK
4/9/2021 6
