Size: 3.125 x 10.5
Design Span (L): 35.75 ft.
Clear Span: 35.50 ft.
Total Span: 36.00 ft.
Selfweight: 275.0 lbs
Dist. Selfweight: 7.69 plf
Total Weight: 276.9 lbs
Lateral Support: 12' o/c
CL Beam Stability Factor 0.898 - - - - -
Beam Design 2021A235
4/8/2021 1
b = 3.125 in.
d = 10.500 in.
A = 3.125 x 10.500 = 32.81 in.2
Sx = (3.125)(10.500)2/6 = 57.42 in.3
Sy = (3.125)2(10.500)/6 = 17.09 in.3
Ix = (3.125)(10.500)3/12 = 301.46 in.4
Iy = (3.125)3(10.500)/12 = 26.70 in.4
4/8/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [32.81 x (429.00 + 3)] x (12 in./ft.)3 = 8.20 ft3
Volumespan = N[A x L] = 1 x [32.81 x 429.00] x (12 in./ft.)3 = 8.15 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 8.20 = 276.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 8.15 = 275.0 lbs
  ws = 7.69 plf
35.75 ft.
35.50 ft.
36.00 ft.
3288.47 lbs
3288.47 lbs
4/8/2021 3
lu = Unbraced Length = 12 ft.
lu/d = = 13.71
le = 1.63lu + 3d = 1.63(144.0) + 3(10.5) = 266.22 in. = 22.18 ft.  (NDS Table 3.3.3)
Rb = = 16.92
 Rb = 16.92 < 50   ➜  OK
4/8/2021 4
FbE = = 3563.45 psi
CL =   = 0.898
CL = 0.898 < CV = 1.0
Fbx' = (2400)(1.15)(1)(1)(0.898) = 2477.4 psi
fb = = 6099.4 psi
 fb = 6099.4 psi > Fbx' = 2477.4 psi  (CSI = 2.46)   ➜  NG
fv* = = 141.98 psi
4/8/2021 5
 fv* = 141.98 psi < Fvx' = 304.75 psi  (CSI = 0.47)   ➜  OK
fv = = 149.29 psi
 fv = 149.29 psi < Fvx' = 304.75 psi  (CSI = 0.49)   ➜  OK
ΔLL = = 6.77 in.
(L/d)LL = 429.00 / 6.77 = 63
 ΔLL = 6.77 in = L/63 > L/360   ➜  NG
ΔTL = = 12.37 in.
(L/d)TL = 429.00 / 12.37 = 35
 ΔTL = 12.37 in = L/35 > L/240   ➜  NG
4/8/2021 6
fc⊥ = = 350.8 psi
 fc⊥ = 350.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.54)   ➜  OK
4/8/2021 7
