Size: 5.5 x 18
Design Span (L): 29.50 ft.
Clear Span: 29.00 ft.
Total Span: 30.00 ft.
Selfweight: 719.3 lbs
Dist. Selfweight: 24.38 plf
Total Weight: 731.5 lbs
CV Volume Factor 0.922b - - - - -
Beam Design 2021A233
4/8/2021 1
d = 18.000 in.
4/8/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [99.00 x (354.00 + 6)] x (12 in./ft.)3 = 20.63 ft3
Volumespan = N[A x L] = 1 x [99.00 x 354.00] x (12 in./ft.)3 = 20.28 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 20.63 = 731.5 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 20.28 = 719.3 lbs
Distributed Self Weight (ws) = = 24.38 plf
  ws = 24.38 plf
29.50 ft.
29.00 ft.
30.00 ft.
2990.75 lbs
2990.75 lbs
4/8/2021 3
CV = = 0.922
CV = 0.922 < CL = 1
Fbx' = (2400)(1.15)(0.8)(1)(0.922) = 2035.0 psi
fb = = 876.3 psi
 fb = 876.3 psi < Fbx' = 2035.0 psi  (CSI = 0.43)   ➜  OK
4/8/2021 4
fv* = = 40.03 psi
 fv* = 40.03 psi < Fvx' = 266.66 psi  (CSI = 0.15)   ➜  OK
fv = = 44.56 psi
 fv = 44.56 psi < Fvx' = 266.66 psi  (CSI = 0.17)   ➜  OK
4/8/2021 5
ΔLL = = 0.43 in.
(L/d)LL = 354.00 / 0.43 = 833
 ΔLL = 0.43 in = L/833 < L/360   ➜  OK
ΔTL = = 0.85 in.
(L/d)TL = 354.00 / 0.85 = 418
 ΔTL = 0.85 in = L/418 < L/240   ➜  OK
fc⊥ = = 90.6 psi
 fc⊥ = 90.6 psi < Fc⊥x' = 344.50 psi  (CSI = 0.26)   ➜  OK
4/8/2021 6
