Design Span (L): 11.33 ft.
Clear Span: 10.83 ft.
Total Span: 11.83 ft.
Live Load: 50 plf
Dead Load: 200 plf
Selfweight: 102.5 lbs
Dist. Selfweight: 9.04 plf
Total Weight: 107.0 lbs
Beam Design 2021A231
4/7/2021 1
4/7/2021 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (136.00 + 6)] x (12 in./ft.)3 = 2.77 ft3
Volumespan = N[A x L] = 2 x [16.88 x 136.00] x (12 in./ft.)3 = 2.66 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 2.77 = 107.0 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 2.66 = 102.5 lbs
Distributed Self Weight (ws) = = 9.04 plf
50 plf
200 plf
ws = 9.04 plf
11.33 ft.
10.83 ft.
11.83 ft.
1532.63 lbs
1532.63 lbs
4/7/2021 3
Fbx' = (750)(1.15)(1)(1)(1)(1)(1)(1.15) = 991.9 psi
fb = = 788.6 psi
 fb = 788.6 psi < Fbx' = 991.9 psi  (CSI = 0.80)   ➜  OK
4/7/2021 4
fv* = = 54.45 psi
 fv* = 54.45 psi < Fvx' = 195.21 psi  (CSI = 0.28)   ➜  OK
fv = = 65.24 psi
 fv = 65.24 psi < Fvx' = 195.21 psi  (CSI = 0.33)   ➜  OK
4/7/2021 5
ΔLL = = 0.04 in.
(L/d)LL = 136.00 / 0.04 = 3287
 ΔLL = 0.04 in = L/3287 < L/360   ➜  OK
ΔTL = = 0.21 in.
(L/d)TL = 136.00 / 0.21 = 634
 ΔTL = 0.21 in = L/634 < L/240   ➜  OK
fc⊥ = = 85.1 psi
 fc⊥ = 85.1 psi < Fc⊥x' = 378.55 psi  (CSI = 0.22)   ➜  OK
4/7/2021 6
