Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 25 plf
Dead Load: 20 plf
Selfweight: 61.7 lbs
Dist. Selfweight: 3.92 plf
Total Weight: 62.7 lbs
Beam Design 2021A23
1/8/2021 1
Beam Design 2021A23
1/8/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (189.00 + 3)] x (12 in./ft.)3 = 1.83 ft3
Volumespan = N[A x L] = 2 x [8.25 x 189.00] x (12 in./ft.)3 = 1.80 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.83 = 62.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.80 = 61.7 lbs
25 plf
20 plf
ws = 3.92 plf
15.75 ft.
15.50 ft.
391.35 lbs
391.35 lbs
Beam Design 2021A23
1/8/2021 3
fb = = 1203.5 psi
 fb = 1203.5 psi < Fbx' = 1345.5 psi  (CSI = 0.89)   ➜  OK
Beam Design 2021A23
1/8/2021 4
fv* = = 32.98 psi
 fv* = 32.98 psi < Fvx' = 207.00 psi  (CSI = 0.16)   ➜  OK
fv = = 35.02 psi
 fv = 35.02 psi < Fvx' = 207.00 psi  (CSI = 0.17)   ➜  OK
Beam Design 2021A23
1/8/2021 5
ΔLL = = 0.52 in.
(L/d)LL = 189.00 / 0.52 = 363
 ΔLL = 0.52 in = L/363 < L/240   ➜  OK
ΔTL = = 1.02 in.
(L/d)TL = 189.00 / 1.02 = 186
 ΔTL = 1.02 in = L/186 < L/180   ➜  OK
fc⊥ = = 43.5 psi
 fc⊥ = 43.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.07)   ➜  OK
Beam Design 2021A23
1/8/2021 6
