Design Span (L): 11.33 ft.
Clear Span: 10.83 ft.
Total Span: 11.83 ft.
Live Load: 400 plf
Dead Load: 100 plf
Selfweight: 153.7 lbs
Dist. Selfweight: 13.56 plf
Total Weight: 160.5 lbs
Beam Design 2021A229
4/6/2021 1
4/6/2021 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (136.00 + 6)] x (12 in./ft.)3 = 4.16 ft3
Volumespan = N[A x L] = 3 x [16.88 x 136.00] x (12 in./ft.)3 = 3.98 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 4.16 = 160.5 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 3.98 = 153.7 lbs
Distributed Self Weight (ws) = = 13.56 plf
400 plf
ws = 13.56 plf
11.33 ft.
10.83 ft.
11.83 ft.
3038.50 lbs
3038.50 lbs
4/6/2021 3
Fbx' = (750)(1.15)(1)(1)(1)(1)(1)(1.15) = 991.9 psi
fb = = 1042.3 psi
 fb = 1042.3 psi > Fbx' = 991.9 psi  (CSI = 1.05)   ➜  NG
4/6/2021 4
fv* = = 71.96 psi
 fv* = 71.96 psi < Fvx' = 195.21 psi  (CSI = 0.37)   ➜  OK
fv = = 86.23 psi
 fv = 86.23 psi < Fvx' = 195.21 psi  (CSI = 0.44)   ➜  OK
4/6/2021 5
ΔLL = = 0.22 in.
(L/d)LL = 136.00 / 0.22 = 616
 ΔLL = 0.22 in = L/616 < L/360   ➜  OK
ΔTL = = 0.28 in.
(L/d)TL = 136.00 / 0.28 = 480
 ΔTL = 0.28 in = L/480 < L/240   ➜  OK
fc⊥ = = 112.5 psi
 fc⊥ = 112.5 psi < Fc⊥x' = 378.55 psi  (CSI = 0.30)   ➜  OK
4/6/2021 6
