Grade: 24F-V8 1.8E SP/SP
Size: 3.5 x 9.625
Design Span (L): 11.33 ft.
Clear Span: 10.83 ft.
Total Span: 11.83 ft.
Live Load: 400 plf
Dead Load: 100 plf
Selfweight: 97.8 lbs
Dist. Selfweight: 8.63 plf
Total Weight: 102.1 lbs
Beam Design 2021A227
4/6/2021 1
d = 9.625 in.
A = 3.500 x 9.625 = 33.69 in.2
Sx = (3.500)(9.625)2/6 = 54.04 in.3
Sy = (3.500)2(9.625)/6 = 19.65 in.3
Ix = (3.500)(9.625)3/12 = 260.07 in.4
Iy = (3.500)3(9.625)/12 = 34.39 in.4
4/6/2021 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [33.69 x (136.00 + 6)] x (12 in./ft.)3 = 2.77 ft3
Volumespan = N[A x L] = 1 x [33.69 x 136.00] x (12 in./ft.)3 = 2.65 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 2.77 = 102.1 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 2.65 = 97.8 lbs
Distributed Self Weight (ws) = = 8.63 plf
400 plf
  ws = 8.63 plf
11.33 ft.
10.83 ft.
11.83 ft.
3009.31 lbs
3009.31 lbs
4/6/2021 3
fb = = 1813.3 psi
 fb = 1813.3 psi < Fbx' = 2760.0 psi  (CSI = 0.66)   ➜  OK
4/6/2021 4
fv* = = 110.17 psi
 fv* = 110.17 psi < Fvx' = 345.00 psi  (CSI = 0.32)   ➜  OK
fv = = 128.33 psi
 fv = 128.33 psi < Fvx' = 345.00 psi  (CSI = 0.37)   ➜  OK
4/6/2021 5
ΔLL = = 0.32 in.
(L/d)LL = 136.00 / 0.32 = 429
 ΔLL = 0.32 in = L/429 < L/360   ➜  OK
ΔTL = = 0.40 in.
(L/d)TL = 136.00 / 0.40 = 337
 ΔTL = 0.40 in = L/337 < L/240   ➜  OK
fc⊥ = = 143.3 psi
 fc⊥ = 143.3 psi < Fc⊥x' = 740.00 psi  (CSI = 0.19)   ➜  OK
4/6/2021 6
