Grade: DF SS
Design Span (L): 16.45 ft.
Clear Span: 16.20 ft.
Total Span: 16.70 ft.
Live Load: 27 plf
Dead Load: 27 plf
Selfweight: 54.2 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 55.0 lbs
Beam Design dfhg
4/5/2021 1
Beam Design dfhg
4/5/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (197.40 + 3)] x (12 in./ft.)3 = 1.61 ft3
Volumespan = N[A x L] = 1 x [13.88 x 197.40] x (12 in./ft.)3 = 1.59 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.61 = 55.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.59 = 54.2 lbs
27 plf
27 plf
ws = 3.30 plf
16.45 ft.
16.20 ft.
16.70 ft.
478.42 lbs
478.42 lbs
Beam Design dfhg
4/5/2021 3
Fbx' = (1500)(1.00)(1)(1)(1)(1.1)(1)(1) = 1650.0 psi
fb = = 1087.2 psi
 fb = 1087.2 psi < Fbx' = 1650.0 psi  (CSI = 0.66)   ➜  OK
Beam Design dfhg
4/5/2021 4
fv* = = 46.17 psi
 fv* = 46.17 psi < Fvx' = 180.00 psi  (CSI = 0.26)   ➜  OK
fv = = 50.95 psi
 fv = 50.95 psi < Fvx' = 180.00 psi  (CSI = 0.28)   ➜  OK
Beam Design dfhg
4/5/2021 5
ΔLL = = 0.24 in.
(L/d)LL = 197.40 / 0.24 = 834
 ΔLL = 0.24 in = L/834 < L/240   ➜  OK
ΔTL = = 0.50 in.
(L/d)TL = 197.40 / 0.50 = 393
 ΔTL = 0.50 in = L/393 < L/180   ➜  OK
fc⊥ = = 106.3 psi
 fc⊥ = 106.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.17)   ➜  OK
Beam Design dfhg
4/5/2021 6
